Using diff. tunes with same octane
Old Feb 21, 2006 | 09:20 AM
turboscrew2005's Avatar
I have the evolution and am currently running the towing tune with 89 octane and timing +1. Has anyone ever ran the performance tune with lower octane and adjusted the timing down a little? Would it hurt anything as long as you hear no pinging? I just put my Terra Grapplers on and they take away a little of the low end grunt and I figured I could get it back with the performance tune.
Old Feb 21, 2006 | 11:38 AM
asinatra's Avatar
Our PCM does a good job of controlling knock if you 'accidently' use a lower grade of fuel. If you are worried just set it back and *gear* it up.
Old Feb 21, 2006 | 11:40 AM
Rockpick's Avatar
Moderator &
Very correct... the knock sensor system on our motors is actually VERY advanced.
Not a huge deal but, try to stick with the octane recommended with your respective tune.
Old Feb 21, 2006 | 02:07 PM
FX4_Guy's Avatar
I'd stick with what they recommend. Edge recommends 91+ on the #3 tune. It's only .20cents more a gallon which will only be a few more dollars a fillup. Chaulk the few dollars more as the cost for better gas mileage and more of a fun -to-drive factor.
Old Feb 21, 2006 | 03:05 PM
expy03's Avatar
ASEMechanic has stated it is best not to do level 3 without at least 91 octane.
Old Feb 21, 2006 | 03:36 PM
CO FX4's Avatar
I've run premium grade gas ever since I've had a tuner. I'm an Evolution user now and have a question with a different twist. That is, same octane (91), same timing advance (3+), but running the level 2 tow vs. the level 3 performance. Question is, is there a whole helluva difference? I've read the level 2 tow tune runs a bit cooler (?) and may have some lower rpm grunt than the level 3. The level 3 is for higher rpm (over 3k). So if I want the advantage of the tow tune/lower rpm torque, I can simply increase my timing and have the best of both worlds? What's everyone say?
Old Feb 21, 2006 | 04:11 PM
expy03's Avatar
If you want to keep running 91 octane, and using level 2, it sounds good to me. That would be a good question to ask Bill on his radio show Thursday night, if we don't hear from him sooner.
Old Feb 21, 2006 | 05:30 PM
ThumperMX113's Avatar
I've been running 93 octane on level 3 with the timing set at +1.5.
Im getting 2 more mpg running 93 octane and its only a few more dollars, plus it makes the truck a whole new beast even with 35s.
