PCV Valve Removal
Old Feb 20, 2006 | 10:39 PM
mfraz4.6's Avatar
Question PCV Valve Removal
Hey Everyone. New to the site, well in terms of posts. 04 F-150 4.6 2V Quite simply how do I replace the PCV valve. I'm sure its simple but did not want to mess up.
Old Feb 21, 2006 | 02:18 PM
Y2KWHT150's Avatar
I know this truck is not as easy as our previous gen. this is according to my OEM service dvd's.
Old Feb 21, 2006 | 09:44 PM
mfraz4.6's Avatar
I assume its on the valve cover with the oil filter neck. But do you just need to pull, twist, or are there any "special" little tabs to press???
Old Feb 21, 2006 | 11:19 PM
Rochester's Avatar
I know how to do the 5.4 but not yours. Can you take a picture of it? I used to manufacture these valves but I am not familiar with yours. If I see it I may be able to help you.
Old Feb 22, 2006 | 12:09 AM
Y2KWHT150's Avatar
Your 4.6 PCV valve is located on the oil filler valve cover area. Here is the brief note on how to...
Remove the engine appearance cover.
Item Part Number Description
1 6K817 Positive crankcase ventilation (PCV) hose quick-release fitting
Removal Note
Installation Note
2 6A666 PCV valve
3 ? PCV valve O-ring seal (part of 6B890)
To install, reverse the removal procedure.
