broken plug!! but got it out!!!!!!!!!!!!!!
Old Feb 17, 2006 | 02:48 PM
ONE04FX4's Avatar
Talking broken plug!! but got it out!!!!!!!!!!!!!!
i ran into this as well. I was able to put the plug back in and drive it for a while. eventually i went ahead and began to try to remove it. 4 hours later and two screwdrivers and two easy outs i was able to get it out. first i removed the porcelan from one of the plugs and drilled it out to 7/16 for the easy outs to go thru. then i used a screw driver to gently pull back the outer edges away from the block. i finally got it to spin. then i took and welded an easy out to the end of a long screw driver. it was the fluted style. after working it around for what seemed as forever i was able to get it to come out. oh yay i put grease in the broke off piece first to stop the shavings. now the new set is in. man i know the feeling now. i think i actually jumped up and down a couple a times when i got it out. i will post pics of the tools monday.
Old Feb 17, 2006 | 02:55 PM
asinatra's Avatar
your heart must of sank to see the plug with no tip come out
Old Feb 17, 2006 | 03:29 PM
2004_FX4's Avatar
You are probably the only person in the world to do this, please provide photos!! I would like the know the "backup" plan next time I change my plugs. Thanks.
Old Feb 17, 2006 | 04:01 PM
ford2004F150's Avatar
Just curious... did you notice any difference from the old plugs to the new ones? Was it really worth all that effort in the end?
Any gains?
Have a banana for you efforts on getting that nasty plug out.
Old Feb 17, 2006 | 04:07 PM
RamSS/T's Avatar
Ok now that you got them out whats to keep the new ones from sticking? Are you going to take them out every 15,000 miles and clean/replace them? To me its just not worth it...if I still have the truck when they NEED to be replaced I will deal with it then. But I am glad you got yours out...it shows a little enginuity goes a long way!!!
Old Feb 17, 2006 | 07:30 PM
Matt 05'FX4's Avatar
How may miles are on your truck? How bad were they rusted? Was the engine hot or cold when you did this?
Old Feb 18, 2006 | 10:20 AM
FATHERFORD's Avatar
I found out through all my callings that there is a tool made to remove these.... I'm just trying to found out where to buy the tool.
Old Feb 18, 2006 | 01:24 PM
ONE04FX4's Avatar
Talking
ok the engine was luke warm when i started but by the time i got her out it was cold. as for a difference--only a little smoother idle. 22000 miles on her. as for keeping them from doing it again. i cleaned the holes the best i could with brakeclean and then turned the engine over to blow out the cylinders. then i put on some nickel antisieze on them. since i am a mechanic and love being one i will prolly remove them ever so often and checkand clean them. i will get some pics soon.
Old Feb 18, 2006 | 02:10 PM
silverbullet5.4's Avatar
Dayum, you only have 22k miles and it broke??!!!! Great, this keeps getting better and better.
Old Feb 18, 2006 | 02:13 PM
That's what I was thinking.......
Old Feb 20, 2006 | 08:00 AM
roboots21's Avatar
What I am wondering, I think it may have been discussed to some extent before, is what type of driving do you do? Do you do lots of short driving, say 5-10 minute drives most of the time? I wonder if this accounts for people having their plugs rust in the head. I have two 30 minute drives every day, so hopefully my plugs will not have much rust buildup on them, as my truck gets through the heat cycle usually every time I drive it. It was just a thought that i remember being discussed to some extent, but I would be interested to see what type of driving you do (short trips, highway, moderate lenght trips, etc.)
Thanks!
Old Feb 20, 2006 | 09:23 AM
FATHERFORD's Avatar
Thanks!
I do mostly long drives, 30 minutes each way every day....
On a side note, after letting my broken plug sit for a week in liquid wrench, it came right out.... Which sucks cause now I have on reason to pull the engine it build it up, oh well.:o
Old Feb 20, 2006 | 12:02 PM
roboots21's Avatar
How many miles did you have when you pulled your plugs? I have 22,000 at the moment. I think I am going to do mine in the spring here pretty soon. I want to do them, but at the same time I am worried about doing them, as this is my daily driver, and can't be without it. But then again I am not sure how long I am keeping this truck, so I don't want to be stuck having to pull both heads cause I waited until I had 100,000+ to change them.....
Old Feb 20, 2006 | 01:06 PM
Josiah's Avatar
I didn't catch that last part. Are you saying you're pulling the engine.
Old Feb 20, 2006 | 01:14 PM
asinatra's Avatar
He was wanting to build it up, but he found the powder casted pistons rule and are good up to 2000hp.
