Guys with Brake Issues new TSB 05-21-19
I've always had a little vibration but it has been starting to get worse. Recently I think my e-brake has been acting up to make the whole truck "shudder" like others have talked about. It finally gave out. Going to the dealership armed with good info tomorrow!
For what it's worth, I've been driving around for a couple weeks now on these new calipers. So far, so good. Pedal feel is good, probably better than it was with the original stuff, stops straight and true, no pulsations. I replaced the rotors on my truck before, so I resurfaced them this time with an Accuturn on car brake lathe, removing about .015" on each side of each rotor. And for y'all that really worry about it, brake dust seems to be lessened with these new pads as well.
TSB 05-21-19
10/31/05
FRONT BRAKE ROUGHNESS - SHUDDER WHILE BRAKING
FORD:
2004-2005 F-150
This article supersedes TSB 05-06-21 to add new parts and update Service Procedure.
ISSUE
Some 2004/2005 F-150 vehicles built before 11/29/2004 may exhibit front brake roughness and or shudder while braking.
ACTION
Service the rack and pinion, rotors, and caliper assemblies as needed, based on vehicle build date and current part levels installed on the vehicle. Refer to the following Service Procedure.
SERVICE PROCEDURE
1. Vehicles built prior to 8/20/2003 require the replacement of the rack and pinion assembly if it has not been replaced. Refer to Workshop Manual, Section 206-03 and 211-02.
2. Determine if the vehicle has the old or new level rotors (Figure 1).
a. If old level rotors, replace the front rotors and front caliper assemblies. Refer to Workshop Manual, Section 206-00 for front rotor and caliper replacement.
NOTE WHEN REPLACING THE ROTORS ON 4X2 UNITS, A NEW SPINDLE NUT IS REQUIRED.
b. If new level (47 fin) rotors are present, perform one (1) of the following:
(1) If rotors are within minimum thickness specifications, machine the rotors using the Rotunda on vehicle brake lathe and the Rotunda adapter kit 201-R0093. Refer to the Workshop Manual, Section 206-00 for the correct on-vehicle brake lathe procedure.
(2) If rotors are beyond machinable thickness, the front rotors must be replaced.
3. Install new service fix calipers.
NOTE REPLACE CALIPERS WITH NEW SERVICE FIX CALIPER ASSEMBLIES BY REMOVING THE CALIPERS AT THE KNUCKLES. THE SERVICE REPLACEMENT CALIPERS WILL BE PRE-ASSEMBLED WITH ANCHOR, SPRINGS, AND PADS. THE CALIPERS SHOULD BE INSTALLED AS A UNIT WITHOUT DISASSEMBLY.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
052119A 2004-2005 F-150 4X2 Built 2.3 Hrs.
Prior To 8/20/2003:
Replace Steering Rack
And Pinion, Front Brake
Calipers, Refinish Rotors
(Do Not Use With 3504A,
2000A, 2001BFA,
2001B2P, 2001B2PT,
2001B5F, 2001B5FT,
2001B8F, 2001B8FT)
052119B 2004-2005 F-150 4X2 Built 1.9 Hrs.
Prior To 8/20/2003:
Calipers, Replace Rotors
2000A, 2001BFA,
2001B2P, 2001B2PT,
2001B5F, 2001B5FT,
2001B8F, 2001B8FT)
052119C 2004-2005 F-150 4X2 Built 1.4 Hrs.
After 8/20/2003: Replace
Front Brake Calipers,
Refinish Rotors (Do Not
Use With 3504A, 2000A,
2001BFA, 2001B2P,
2001B2PT, 2001B5F,
2001B5FT, 2001B8F,
2001B8FT)
052119D 2004-2005 F-150 4X2 Built 0.9 Hr.
Replace Rotors (Do Not
2001BFA, 2001B2P,
2001B2PT, 2001B5F,
2001B5FT, 2001B8F,
2001B8FT)
052119E 2004-2005 F-150 4X4 Built 2.6 Hrs.
Prior To 8/20/2003:
2000A, 2OO1BFA,
2001B2P, 2001B2PT,
2001B5F, 2001B5FT,
2001B8F, 2001B8FT)
10/31/05
FORD:
2004-2005 F-150
ISSUE
ACTION
SERVICE PROCEDURE
Parts Block
Prior To 8/20/2003:
2000A, 2001BFA,
2001B2P, 2001B2PT,
2001B5F, 2001B5FT,
2001B8F, 2001B8FT)
Prior To 8/20/2003:
2000A, 2001BFA,
2001B2P, 2001B2PT,
2001B5F, 2001B5FT,
2001B8F, 2001B8FT)
2001BFA, 2001B2P,
2001B2PT, 2001B5F,
2001B5FT, 2001B8F,
2001B8FT)
2001BFA, 2001B2P,
2001B2PT, 2001B5F,
2001B5FT, 2001B8F,
2001B8FT)
Prior To 8/20/2003:
2000A, 2OO1BFA,
2001B2P, 2001B2PT,
2001B5F, 2001B5FT,
2001B8F, 2001B8FT)
052119F 2004-2005 F-150 4X4 Built 2.0 Hrs.
Prior To 8/20/2003:
2000A, 2001BFA,
2001B2P, 2001B2PT,
2001B5F, 2001B5FT,
2001B8F, 2001B8FT)
052119G 2004-2005 F-150 4X4 Built 1.5 Hrs.
2001BFA, 2001B2P,
2001B2PT, 2001B5F,
2001B5FT, 2001B8F,
2001B8FT)
052119H 2004-2005 F-150 4X4 Built 0.9 Hr.
2001BFA, 2001B2P,
2001B2PT, 2001B5F,
2001B5FT, 2001B8F,
2001B8FT)
DEALER CODING
CONDITION
BASIC PART NO. CODE
2B120 42
OASIS CODES: 301000, 303000, 703000
Prior To 8/20/2003:
2000A, 2001BFA,
2001B2P, 2001B2PT,
2001B5F, 2001B5FT,
2001B8F, 2001B8FT)
2001BFA, 2001B2P,
2001B2PT, 2001B5F,
2001B5FT, 2001B8F,
2001B8FT)
2001BFA, 2001B2P,
2001B2PT, 2001B5F,
2001B5FT, 2001B8F,
2001B8FT)
DEALER CODING
CONDITION
BASIC PART NO. CODE
2B120 42
TSB 05-6-21
04/04/05
FRONT END SHUDDER/VIBRATION WHEN
BRAKING - VEHICLES BUILT BEFORE 11/18/2004
FORD:
2004-2005 F-150
This article supersedes TSB 05-05-02 to update the service part numbers.
ISSUE
Some 2004-2005 F-150 vehicles built before 11/18/2004 may exhibit a shudder/vibration from the front brakes when braking.
ACTION
Replace the front rotors. On vehicles built prior to 8/20/2003 also replace the rack and pinion. Refer to Workshop Manual Sections 206-03 and 211-02.
Parts Block
050621A 2004-2005 F-150 4x2 0.7 Hr.
Replace Front Brake
Rotors (Includes Time To
Check Vehicle Build Date)
(Do Not Use With
2001B5T, 2001B5F,
3504A)
050621A 2004-2005 F-150 4x4 0.6 Hr.
Replace Front Brake
(Do Not Use With
2001B5T, 2001B5F,
3504A)
050621B 2004-2005 F-150 4x2 1.7 Hrs.
Replace Front Brake
Rotors, And Rack And
Pinion (Includes Time To
(Do Not Use With
2001B5T, 2001B5F,
3504A)
050621B 2004-2005 F-150 4x4 1.8 Hrs.
Replace Front Brake
(Do Not Use With
2001B5T, 2001B5F,
3504A)
DEALER CODING
CONDITION
BASIC PART NO. CODE
1102 91
04/04/05
FORD:
2004-2005 F-150
ISSUE
ACTION
Parts Block
Replace Front Brake
(Do Not Use With
2001B5T, 2001B5F,
3504A)
Replace Front Brake
(Do Not Use With
2001B5T, 2001B5F,
3504A)
Replace Front Brake
(Do Not Use With
2001B5T, 2001B5F,
3504A)
Replace Front Brake
(Do Not Use With
2001B5T, 2001B5F,
3504A)
DEALER CODING
CONDITION
BASIC PART NO. CODE
1102 91
Originally Posted by donnyb
I have a good friend who is a very experienced mechanic. He helped me replace the ABS control box on my old Blazer. We had to bleed the brakes for a verrrry long time to clear all the air in the lines. During that time, he told me most dealership mechanics are in such a hurry to finish they don't take the time to completely & properly bleed brakes. His reccomendation is to bleed as much air out as possible, till you have reasonable pedal, then drive the vehicle around a bit using the brakes, like in a parking lot, then bleed again till you have a good hard pedal. Repeat as necessary...
I have an 04 screw and just had the tsb done on mine. Yes, I had the older narrow rotors. They replaced whole front brake system as described in the tsb. Drove it off the lot, & whoa, soft pedal. Drove right back in & said this is not right. Tech came out & I said I thought there was still some air in the lines, I could push the pedal (hard) nearly to the floor. He drove it around in the lot, stomping on the brakes, took it back into the service area & bled brakes some more. Came out & said they were fine, bleeding was clear fluid. But, when I got back in, the pedal was much better. Not as hard as before the tsb service but much better than before. So truth is he DID have air in the lines. Try bleeding the soft pedal and be prepared for it to take a while and use up a lot of fluid.
For what its worth, the steering wheel no longer shakes when I brake hard at speed, so I think the tsb worked for me.
