Continued: Edge 91 vs My/Bama 91 + No tune
Old Feb 18, 2006 | 01:04 AM
  #31
RamSS/T's Avatar
Originally Posted by asinatra
My/BamaChips 91 *understand that my tune is a work in progress, but its getting better*
I find it pretty funny that with all the schit he has talked over the last year or so about the 4.6L vs 5.4L that my SCREW, on heavy *** 24s with a canned tune has ran better than a .5 sec faster 0-60 than his RC with stock FX4 rims and a "far superior" custom tune. I guess there really is no replacement for displacement after all!
Old Feb 18, 2006 | 02:06 AM
  #32
Tuff4rd's Avatar
My Fx4 ran a 15.2 @91MPH on level 3, not bad for a 4x4 on some AT tires 305 55 20's.
I likemost here with the Edge are
Old Feb 18, 2006 | 03:05 AM
  #33
Kool Aid's Avatar
Yeah, thats it... Here we go kids...
Second picture: I snapped RIGHT AFTER the run with the edge and laughed my *** off cause it sucked, and that was the best of 3 runs i could get. The EDGE tune was right out of the box, NO CUSTOM SETTINGS, it shifted at around 5500 rpms which *over-rev'ed* the engine 400rpms to late.
The Edge does not shift at 5500 out of the box.....
Old Feb 18, 2006 | 06:22 AM
  #34
gobra's Avatar
I do not know my A/F ratio at WOT, but to make up for that i added a 1.8 fuel multiplier to my program. 80% increase in fuel over the stock should be PLENTY even if my truck is running lean from the factory. All this talk about, "OMG, you DONT KNOW YOUR A/F RATIO!!!!! is just scary rhetoric and i dont buy into it. If i didnt have the EDge, i would be running lean anyway....
I am running the 91 octane and added +2 degrees of timing. I have had zero issues with pinging. I will be adding more timing until i hear the pinging, then back off. I would not recommend this process unless you are comfortable and familiar with the causes and the possible catastrophic results of detonation. I am fairly "confident" in the results of that run because it launched perfect and felt REALLY strong as opposed to some of my other runs. Dont know why it felt stronger, but it did. I will go to the track soon and that will be the proof in the pudding, so to speak.
Old Feb 18, 2006 | 10:51 AM
  #35
hwm3's Avatar
Do you really think the injectors/fuel pump are capable of increasing fueling by 80%? I'm more interested in dyno numbers for the Edge, than track numbers.
Old Feb 18, 2006 | 11:28 AM
  #36
cobraman302's Avatar
I will be going to Modular Depot in Cincinnati on March 4th to dyno my truck with probably the stock settings, then level two, then level three. Does anyone know the best custom settings for sure on this so I can give everyone some real world number improvements, I want to know the full potential of this edge without getting dangerous. All I know so far is that before the airaid, and the mac exhaust it was doing a 7.2 sec 0-60, and a 15.2 in the quarter. Thanks guys.
Old Feb 18, 2006 | 11:41 AM
  #37
billindenver's Avatar
Well 7.2 is still a big jump on the 'superior' tuner...so I think you are in the ballpark. You are only at 483 feet above sea level in cincinnati so you are getting decent air....I would try +2 on timing (listen for ping, adjust as needed) and then let the dyno tell you how much fuel you need to add. Still, 7.2 is not a bad figure on a 4x4. Asin spent a whole ton more money on his tuner than you did and he wouldn't see anything but your tail lights in a race...
Bill
Old Feb 18, 2006 | 01:57 PM
  #38
gobra's Avatar
The fuel system may or may not becapable of supporting 80% more. What do the supercharger companys supply to increase the fuel? Do they send injectors/fuel pumps? Im asking because i dont know. Bottom line is, my fuel system is either up to the task or it's not. If its not, then no TUNER, canned or otherwise will, fix it. I will be getting on the dyno as soon as i can get up with doug from bama chips....
hwm3, you posted your dyno sheets somewhere didnt you? I figure RWHP in the 250 + would be good gains for our trucks.
Old Feb 18, 2006 | 09:26 PM
  #39
MosineeFX4's Avatar
From what others have posted, the Whipple uses the stock pump and injectors.
Old Feb 19, 2006 | 05:06 AM
  #40
fourpointsix's Avatar
Wow, that's quite a stark difference between the Edge and the XCal2. You really need to get those 4.56s in bro! They will help substantially.
Old Feb 19, 2006 | 09:20 AM
  #41
Doo2theSea's Avatar
Originally Posted by Jims05Screw
Gobra,
How far are you pushing the perameters. I like your numbers and I really like the Edge. I dont race but I would like to skeek a little more power out of her as long as I dont blow it up. Although the edge doesnt support my PCM yet so I cant do any customizing......Go figure. Can you send me some set points.
Hey Jim-
I was having the same problem, make sure you follow this exact method bleow and you will be able to custom tune
Originally Posted by ASEMechanic
If anyone should experience this problem:
Turn the key on
Disconnect OBD Cable
Reconnect OBD Cable
Make sure "HEX" code is properly identified
That should fix it.
Take care.
Bill
Old Feb 19, 2006 | 01:52 PM
  #42
rafa26's Avatar
What are your best 0-60mph and 1/4 mile times ? Thanks for you time.
Old Feb 19, 2006 | 01:54 PM
  #43
rafa26's Avatar
What are your best 0-60mph and 1/4 mile times ? Thanks.
Old Feb 19, 2006 | 01:55 PM
  #44
rafa26's Avatar
