Hey Ford Techs--Any tricks to changing a rear axle seal?
Old Feb 12, 2006 | 07:01 PM
nvrenuff's Avatar
I have done in it my mustang with the 8.8 . Is it the same? I want to get this done asap (as soon as the dealer opens up in the morning so I can pick up the seal, put it together and get my a$$ to work)
Is it like this?
Just pull the diff cover off, take that pin retainer bolt out, slide the pin out, push in the axle to expose the c-clip, remove the c-clip, and slide out the axle. Will the axle seal come out easy, and does the new one just push in?
As for parts, all I should need is the seal, the oil, and friction modifier, right?
Old Feb 12, 2006 | 07:10 PM
Quintin's Avatar
That about sums it up. You can use the end of the axle shaft to pry the seal out. A big rolling head prybar works like a champ for this too. After that, just beat the new seal in with a hammer. Pick up a couple cans of brake clean to clean the oil residue off the backing plate while you're getting the rest of the stuff.
Old Feb 12, 2006 | 08:38 PM
nvrenuff's Avatar
Thanks Quintin. MUCH appreciated.
