Edge Pod Mounting
Old Feb 5, 2006 | 01:55 PM
chasman97's Avatar
Edge Pod Mounting
For those that have already mounted their Edge Pod to their dash, what were the best locations that were found on the pod for the supplied velcro and or double sided tape. The instructions do not mention this and experience tells me that you only have one shot with these. I'm wondering what locations will give me the snuggest fit to the dash.
thanks for any replies,
chas
Old Feb 5, 2006 | 04:45 PM
F150Truck'in's Avatar
Use the supplied velcro, you DON'T want to roll in the dealer with that pod on your dash...even without the unit in it.. there not dumb, if they see the pod on your dash, they KNOW what it is......
As far as where to put the tape, use masking tape to hold the velcro in place on the pod and test fit to your dash....
Old Feb 5, 2006 | 08:13 PM
JackDob's Avatar
I use the Velco but I just can't seem to get the right spot either. I think it's OK but looks like it is designed for the double stick tape..
The POD fits great without the heavy strip of Velcro.. I spotted mine by attaching the Velco with the backing still on. I untaped and exposed the corners of one side and stuck that to the pod and moved it till I got the best fit.. Still not satisfiled but it works... and the Velcro does it's job when I have to visit my dealer for my first 25K of free maint... :o After that is over I probably will use the double sided tape to get a better fit. Then I will be just doing emissions and I can leave it on the dash... probably won't have to even reprogram.. I see what happens on what I read about other owners experience.
Jack
Old Feb 5, 2006 | 11:22 PM
KiCk aSs FX4's Avatar
I used the double sided tape. The velcro is too thick and it will make a gap between the dash and your pod. I put one in the front and one in the back. Both about a 1/4 inch away from the end.
Old Feb 5, 2006 | 11:23 PM
ThumperMX113's Avatar
It stays put without the use of either, so why would you put it on your dash? I go offroad and have never had a problem with it bouncing or even moving.
Old Feb 5, 2006 | 11:25 PM
they why do they give it to you?
Old Feb 5, 2006 | 11:28 PM
Good question. .
The guys at Edge probally sleep better at night knowing that they gave you the option.
Old Feb 5, 2006 | 11:30 PM
i was really confused when they gave me 2 of each. I thought you were suppose to use them all. At first I thought the velcro was suppose to go on the edge and the pod.
Old Feb 5, 2006 | 11:33 PM
Exactly, they just figured overkill was better than no kill.
Old Feb 6, 2006 | 12:37 AM
Forrest_F150's Avatar
i haven't used either method yet....
i am afraid either way the pod will eventually scratch my dash from the vibration and shifting over time.....
so, for now i have it just sitting there with a paper towel under it until i figure out how to mount it so it doens't scratch the dash over time...
Old Feb 6, 2006 | 01:00 AM
Nates06SCab's Avatar
I mounted it in the ash tray. Kind of hard to read there, but I t gives me piece of mind against thieves.
Old Feb 6, 2006 | 01:37 AM
Kool Aid's Avatar
Ditto, except I have no trouble reading it.
Old Feb 6, 2006 | 01:11 PM
khendrix2374's Avatar
Koolaid... You actuall have change in that "Chang holder"?
I put a couple coins in it ONCE... rattled so bad pulling out of my driveway.. I took em out..
Old Feb 6, 2006 | 02:42 PM
craig41071's Avatar
try a small dab of silicone on each side not to much though, later you can pull off and rub off the dried silicone without messing up the dash. Fits tight no gaps
Old Feb 6, 2006 | 02:43 PM
craig41071's Avatar
Silicone, duct tape and makeup, and birth control pills
MANS GREATEST INVENTIONS!
