Tsb Reports
Old Nov 15, 2006 | 11:48 AM
OnBelay's Avatar
Originally Posted by marlin39d
Glad my truck is not an '04-'05.
But I bet my 2006 will have a TSB or two as time rolls on!!! But @ 5600 miles all seems A-OK so far.
Uhhh...better get off your pedestal. It already has more than a "TSB or two"
TSB Number & Issue Date TSB Title
06C11S1 FEB 06 Recall - Instrument Cluster Programming for ABS Light
05S40S1 DEC 05 Recall - Wiper Motor Inspection/Lubrication
05B34S1 JAN 06 Campaign - Tire Replacement
06-12-3 JUN 06 Driveline - Highway Speed Vibration
06-12-2 JUN 06 Drivetrain/Wheels/Tires - High Speed Vibration
06-12-10 JUN 06 Engine Controls - MIL ON/DTC P0607 Set
06-11-3 JUN 06 Drivetrain - Shudder Vibration On Hard Acceleration
06-11-12 JUN 06 Frame - L/H Front Differential Bracket Frame/Separation
06-10-8 MAY 06 Engine Controls - Hard Start/High Idle/MIL ON/DTC P0606
06-10-9 MAY 06 Frame - Replacement Matrix Service Tip
06-9-8 MAY 06 Drivetrain - ESOF System Inoperative/DTC P1867
06-9-11 MAY 06 Engine - Loud Valve Train Ticking Noise
06-8-2 MAY 06 A/T - Uncommanded TCC Lock-Up on 1-2 Shift
06-8-15 MAY 06 Axle - Intermittent Noise, 4 X 4 Inop. DTC's 1979 & 1980
06-7-1 APR 06 Vehicle - Tow Capability/Service Kit Requirements
06-4-9 MAR 06 A/C - Compressor Leaking/Inoperative
06-4-2 MAR 06 Battery - Battery EYE Function/Charging Service Tips
06-2-5 FEB 06 Instruments - Power Folding Mirror Operation
05-26-7 DEC 05 Alignment - Rapid Inside Edge Tire Wear
05-26-24 DEC 05 Tires/Wheels - Excessive Run-Out Vibration
05-24-3 DEC 05 Body - Power Back Glass Noise While Driving
05-22-8 NOV 05 Ignition System - Coil-On-Plug Misfire Diagnostic Tips
05-21-18 OCT 05 A/T - Shift Cable Repair or Replacement
05-18-7 SEP 05 Electrical - Wiring Soldering/Crimping Service Tips
05-16-12 AUG 05 Electrical - Wire Harness Replacement Service Tips
05-16-11 AUG 05 Restraints - Seat Belts Slow to Retract
05-9-3 MAY 05 Interior - Repair/Paint to Match Instructions
The thing you everyone needs to realize is that any design process will have some "engineered-in" problems. TSBs recognize those, and address possible repairs. They are not a guarantee that any particular vehicle will have that problem, that diagnosis, or that solution to the problem. They are simply recognition that many vehicles of a particular model have some similarities.
Old Nov 15, 2006 | 12:48 PM
marlin39d's Avatar
You broke my damn pedestal. I tumbled off!!!
Seriously I was not aware of the TSB's already listed for the the 2006 models.
Old Nov 15, 2006 | 06:57 PM
bladefl's Avatar
Thanks for the Info Onbelay.
Quintin,
I understand you are familiar with a lot of these issues. I know my truck has the rolling fan noise at cold start. This really doesn’t bother me that much. What does is the noise of the clutch kicking in and out. For some reason it only does this with the A/C on. The other day I was sitting at the bank drive thru and it seemed to be kicking in and out every 30 seconds or so. My question being, is this "The normal characteristics of the truck" and does this TSB apply to this.
I'm not one to run to the dealer every time a minute issue pops up. Here again my warranty will be running by next fall and I would like to get some of these issues resolved. I feel it’s reasonable to say I paid for the right to do so.
Personally, I don't like anyone working on anything of mine except myself. I have already had a bad experience with a dealer after moving into a new location over a damn cat heat shield rattle. The dealer I bought the truck from has always taken care of me, but unfortunately it’s a 1.5 hour drive from me now. This just gives me a reason to make that trip, get to see the parents, and do some hunting and fishing. It’s just a shame how some dealers treat you like a disposable commodity with little respect or dignity.
As of right now I have a rattling cat heat shield that makes my 35K truck sound like a 73’ Datsun when I’m idling around a parking lot. The parking break mechanism rattles something terrible on rough roads. I also suffer from the notorious bang of a downshift, but I wish to eventually resolve this with the addition of an Edge.
Sorry for the rant, just aggravating none the less.
Old Nov 15, 2006 | 07:25 PM
a n t h o n y's Avatar
Banned
The clicking is the A/C clutch; clicking every 10-30 seconds is normal.
Old Nov 15, 2006 | 07:26 PM
Quintin's Avatar
Originally Posted by bladefl
Quintin,
There is an upgraded fan clutch for this concern. My truck does it too, I just haven't got around to fixing it yet; it won't cause any harm, as in the engine won't overheat or run too cool, it's just annoying.
Old Dec 28, 2006 | 12:43 PM
MeanGene's Avatar
Originally Posted by lawclerksfv
03-22-4 NOV 03 Wheels - Correct Lug Nut Torque Specifications
Could you find out what the correct Lug Nut torque is for our trucks, thanks.
Old Dec 28, 2006 | 01:56 PM
Mister B's Avatar
150 lb-ft
Old Dec 28, 2006 | 02:01 PM
bamorris2's Avatar
150 ft-lbs.
Old Dec 28, 2006 | 02:10 PM
whitecrystal1's Avatar
Does anyone know anything about this one
My wiper motor make noise like a growl when it's used for a little while in the rain. I was starting to thing it might fail on me.
Old Dec 28, 2006 | 02:45 PM
bamorris2's Avatar
What year is that TSB for? I searched under 04 & 05 F150's, and no such TSB exists for those vehicles.
Old Dec 28, 2006 | 02:49 PM
I got that info from post #16 from OnBelay
Old Dec 28, 2006 | 02:58 PM
bamorris2's Avatar
Ok, that was a recall, not a TSB... Guess I should read better, huh? Anyway, here it is...
Originally Posted by Recall
SAFETY RECALL
05S40 Certain 2006 Model Year Cars and Trucks - Wiper Motor Inspection
October 19, 2006
TO: All U.S. Ford and Lincoln Mercury Dealers
SUBJECT: Safety Recall 05S40 Supplement #2
RE: Safety Recall 05S40 Supplement #1 - December 2005
PURPOSE OF THIS SUPPLEMENT
This bulletin is being re-issued to:
Inform dealers that wiper motor grease is no longer available from Ford. When dealers' existing supply of grease is exhausted, all vehicles that are inspected and found to require grease will require wiper motor replacement.
Announce the addition of Labor Operations 05S40D and 05S40E for replacement of the wiper motor that has failed due to lack of grease.
Announce parts return process for replaced wiper motors.
AFFECTED VEHICLES
Certain 2006 Model Year:
Mark LT and F-150 trucks built at:
Norfolk Assembly Plant from September 6, 2005 through October 17, 2005.
Kansas City Assembly Plant from September 6, 2005 through October 17, 2005.
Dearborn Truck Plant from September 12, 2005 through October 17, 2005.
Explorer and Mountaineer vehicles built at:
Louisville Assembly Plant from September 9, 2005 through October 17, 2005.
St. Louis Assembly Plant from September 2, 2005 through October 17, 2005.
Expedition and Navigator vehicles built at:
Michigan Truck Plant from September 12, 2005 through October 17, 2005.
Escape, Escape Hybrid, Mariner and Mariner Hybrid vehicles built at:
Kansas City Assembly Plant from August 29, 2005 through October 17, 2005.
Ranger trucks built at:
Twin Cities Assembly Plant from August 29, 2005 through October 17, 2005.
E-Series vehicles built at:
Lorain Assembly Plant from August 29, 2005 through October 17, 2005.
Taurus vehicles built at:
Atlanta Assembly Plant from September 12, 2005 through October 17, 2005.
Affected vehicles are identified in OASIS. In addition, for a list of vehicles assigned to your dealership, visit https://web.fsavinlists.dealerconnection.com. This information will be available on November 11, 2005
REASON FOR THIS SAFETY RECALL
In some of the affected vehicles, the windshield wiper motor may have been produced without grease being applied to the output shaft gear. After a period of continuous use on the high speed setting, lack of grease on the output shaft gear may cause the gear to distort and/or fracture during operation resulting in a loss of wiper function.
SERVICE ACTION
Dealers are to inspect and determine if the wiper motor was built on the south assembly line. If the wiper motor was built on the south assembly line, dealers are to remove the wiper motor gear cover, inspect for the presence of grease on the wiper motor output shaft gear and, if necessary, apply grease if available in dealer stock (see Attachment III). Wiper Motor Grease is no longer available for ordering. Once a dealer has run out of grease, all vehicles that are inspected and found to require grease or that have failed due to a lack of grease will require motor replacement. It is expected that only a small number of wiper motors will require grease or wiper motor replacement. This service must be performed free of charge on affected vehicles that have been delivered to customers. Do not demonstrate or deliver affected vehicles that remain in your new vehicle inventory until this safety recall has been completed. Please note that if the wiper motor has failed and the wiper motor is NOT within the date codes specified in Attachment III, OR the wiper motor has failed and grease IS present, motor replacement is NOT covered under this program. In this situation, follow the guidelines in the Warranty and Policy Manual.
PLEASE NOTE:
Federal law requires dealers to complete any outstanding safety recall service before a new vehicle is delivered to the buyer or lessee. Violation of this requirement by a dealer could result in a civil penalty of up to $5,000 per vehicle. Correct all vehicles in your new vehicle inventory before delivery.
Copyright © 2006 FORD MOTOR COMPANY
Published By: Recall/Service Programs Department
Ford Customer Service Division
Old Dec 28, 2006 | 03:09 PM
Mine was built in the Dearborn plant but it's a 2005 not a 06. I would need to check my build date to see when it was really built, I would bet it was in the same time frame as the recall. I bought it this year so I think this should apply to mine but since it's a 05 it probably won't. I guess all I can do is let my dealer know about the noise and have them cover it under warranty.
Thanks for the info
Old Dec 28, 2006 | 08:04 PM
MeanGene's Avatar
150 ft-lbs.
Yeah, that is what my manual says, but does the "TBS 03-22-4 NOV 03 Wheels - Correct Lug Nut Torque Specifications" say something different or is it the same?
