Tsb Reports
Old Feb 3, 2006 | 03:09 PM
lawclerksfv's Avatar
Post Tsb Reports
Hey guys, i pulled a list of all the TSB REPORTS off another f150 forum website that i stumbled across
I hope its helpful. I printed it out and highlighted the problems with my truck that i am noticing.
ill post the problems i have read about most
Make : FORD Model : F150 Year : 2004
Manufacturer : FORD MOTOR COMPANY
Service Bulletin Num : 042611 Date of Bulletin: MAR 21, 2005
NHTSA Item Number: 10014683
Component: SERVICE BRAKES, HYDRAULIC
Summary:
FRONT END SHUDDER/VIBRATION WHEN BRAKING - VEHICLES BUILT BEFORE 11/18/2004. *TT
Service Bulletin Num : 05515 Date of Bulletin: MAR 21, 2005
NHTSA Item Number: 10014700
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
ROUGH IDLE - 5.4L AND 4.6L ENGINES. *TT
Service Bulletin Num : 0543 Date of Bulletin: MAR 07, 2005
NHTSA Item Number: 10014643
Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM:FAN
Summary: COOLING FAN CLUTCH NOISE - VEHICLES BUILT PRIOR TO 10/1/2004 - 5.4L AND 4.6L ENGINES. *TT
Old Feb 3, 2006 | 03:10 PM
Service Bulletin Num : 04266 Date of Bulletin: DEC 31, 2004
NHTSA Item Number: 10014275
Component: POWER TRAINRIVELINE
Summary:
A DRIVELINE CLUNK OR BUMP WHEN STARTING FROM A STOP. *TT
Service Bulletin Num : 041501 Date of Bulletin: DEC 31, 2004
NHTSA Item Number: 10014280
Summary: FRONT END SHUDDER/VIBRATION WHEN BRAKING - VEHICLES BUILT BEFORE 11/18/2004. *TT
Service Bulletin Num : 04257 Date of Bulletin: DEC 27, 2004
NHTSA Item Number: 10014252
Component: STEERING
Summary:
VEHICLE/STEERING WHEEL VIBRATION AT 50 MPH (80 KM/H) OR HIGHER - STEERING WHEEL NIBBLE AT 65 MPH (105 KM/H) OR HIGHER. *TT
Old Feb 3, 2006 | 03:12 PM
Service Bulletin Num : 042107 Date of Bulletin: DEC 13, 2004
NHTSA Item Number: 10014086
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
GENERAL (PCM) POWER TRAIN CONTROL MODULE PROGRAMMING PROCEDURES. *TT
Service Bulletin Num : 18342 Date of Bulletin: DEC 01, 2004
NHTSA Item Number: 10014608
Summary:
TICKING NOISE FROM UPPER ENGINE. *EH
Service Bulletin Num : 18250 Date of Bulletin: OCT 01, 2004
NHTSA Item Number: 10010743 Component: POWER TRAIN
Summary:
INTERMITTENT CLUNK ON 3-2 DOWNSHIFT DURING COASTDOWN/TIP-IN. OASIS. TO INCLUDE 2005 F-150, E-SERIES AND EXPEDITION. *TT
Old Feb 3, 2006 | 04:20 PM
asinatra's Avatar
You think you hit a gold mine. But thats only about 1/10th of the actual TSBs out there for the truck.
Old Feb 3, 2006 | 04:39 PM
ThumperMX113's Avatar
He said he was only posting about the ones he read about the most.
Old Feb 3, 2006 | 08:05 PM
Yep, there are TONS of them. Only posted what i thought others may be interested in.
Old Feb 3, 2006 | 08:21 PM
OnBelay's Avatar
05 F150 4X4 5.4:
General Recalls
TSB Number & Issue Date TSB Title
04L24S1 JUN 05 Campaign - Tire Warranty Coverage Changes
04B23S1 MAR 05 Campaign - Pick Up Box Butyl Pad Removal
04B23 FEB 05 Campaign - Truck Box Corrosion Prevention
Service Bulletins
05-14-4 JUL 05 Engine Controls - MIL ON/DTC's P2106 and P2135 Set
05-14-2 JUL 05 Interior - Headliner Buffeting or Rattling
05-13-2 JUL 05 Charging System - DTC's P0340/P0344 Set
05-13-1 JUL 05 Drivetrain - Shudder/Vibration on Hard Acceleration
05-13-4 JUL 05 Fuel System - MIL ON/Rough Idle/Long Crank/Misfire/DTC's
05-12-6 JUN 05 Drivetrain - Drive Axle Whine/Hum on Accel/Decel/Cruise
05-11-9 JUN 05 Body - Rear Bolt-In Glass Installation/Removal Tips
05-10-11 MAY 05 A/C - White Flakes From Vents With Blower ON
05-10-19 MAY 05 Audio System - CD Player Skips/Locks-Up/Inoperative
05-10-12 MAY 05 Engine Controls - Harsh 3-2 A/T Downshifts/No DTC's
05-10-2 MAY 05 Engine Controls - MIL ON/DTC's/Driveability Concerns
05-10-15 MAY 05 Ignition System - Spark Knock/MIL ON/Misfire DTC's Set
05-9-18 MAY 05 Battery - Service/Charging Tips
05-9-3 MAY 05 Interior - Repair/Paint to Match Instructions
05-9-23 MAY 05 Steering - Steering Column Clunk/Rattle Noise
05-6-21 APR 05 Brakes - Front Brakes Shudder/Vibrate Upon Application
05-6-4 APR 05 Instruments - False Parking Aid Warnings
05-5-5 MAR 05 Keyless Entry - Keypad Inoperative
05-4-3 MAR 05 Cooling System - Fan Clutch Noise on Cold Start-Up
05-4-6 MAR 05 Engine Controls - MIL ON/DTC P061B and P2106 Set
05-3-5 FEB 05 Body - Roof Ditch Molding Loose
05-3-1 FEB 05 Engine Controls - MAF Sensor Diagnostic Service Tip
05-3-10 FEB 05 Restraints - Seat Belt Stop Button Service
04-26-17 DEC 04 Body - Weld Bonding (MIG Procedure)
04-26-16 DEC 04 Body - Weld Bonding Procedure
04-26-6 DEC 04 Driveline - Clunk/Bump When Starting From A Stop
04-26-18 DEC 04 Interior - Door Trim Applique Removal Procedure
04-25-17 DEC 04 Body/Frame - Magnesium Radiator Support Service Tips
04-25-8 DEC 04 Steering/Drivetrain - Body Vibration at Highway Speeds
04-25-7 DEC 04 Steering/Drivetrain - Steering Wheel Vibration/Nibble
04-24-5 DEC 04 A/C/Audio - Defroster/Antenna Grid Diagnosis/Repair
04-24-20 DEC 04 Drivetrain - L/S Rear Axle Shudder/Chatter
04-24-24 DEC 04 Engine - Camshaft/Valve Lash Adjuster Design Change
04-24-14 DEC 04 Engine Controls - General PCM Programming Procedures
04-24-21 DEC 04 Restraint System - Seat Belts Slow to retract
04-24-3 DEC 04 Steering - Leather Coming Loose From Steering Wheel
04-16-1 AUG 04 Ignition System - Engine Misfire Diagnostics Tips
04-14-7 JUL 04 Electrical - Wiring Harness Replacement Guidelines/Tips
Alldata
Old Nov 14, 2006 | 11:57 AM
bigmike899's Avatar
Still active?
2004 f150 lariat screw 4x4
Old Nov 14, 2006 | 07:43 PM
OnBelay's Avatar
Originally Posted by bigmike899
Still active?
Huh?
What are you asking?
Old Nov 14, 2006 | 09:04 PM
bladefl's Avatar
I have a build date of 9/04 and think I may suffer from this infliction. Do you have anymore information on it?
Old Nov 14, 2006 | 10:55 PM
OnBelay's Avatar
TSB 05-4-3
03/07/05
FORD:
2004-2005 F-150
ISSUE
Some 2004-2005 F-150 vehicles built prior to 10/1/2004 and equipped with a 5.4L or 4.6L engine, may exhibit a noise coming from the engine cooling fan. The noise may be described as a rolling engine idle, most noticeable just after a cold engine startup and before the fan clutch has warmed up.
ACTION
If the condition is verified, replace the cooling fan clutch per Workshop Manual Section 303-03. The condition can be verified by starting the vehicle cold, placing the transmission into gear and listening for a repeated increase and decrease in cooling fan noise.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
050403A 2004-2005 F-150 4.6L 0.6 Hr.
MFI, 5.4L 3V: Replace The
Cooling Fan Clutch
(Includes Time To Start
Engine And Verify Noise)
(Do Not Use With 8616A)
DEALER CODING
CONDITION
BASIC PART NO. CODE
8A616 42
Old Nov 15, 2006 | 03:48 AM
bobbyspaghetti's Avatar
So how do these TSB's work. I am almost positive I have the rough idle sound fan clutch, the clunk in drive shaft from stopped and I have only got 40,000 kms on my truck and they had to turn my brake rotors. How can I tell if they should be replacing my rotors and not just turning them. I would like to get all this stuff fixed before my bumper to bumper warranty is up. Can I just go in there and say hey "go thru your TSB's and anything that effects my truck fix"
Also if you guys have any info on computer tune versions or updates, like if a perso should go in and see if they have 'better' newer tunes available.
Its a 2004 screw lariat 4x4
Old Nov 15, 2006 | 09:08 AM
Quintin's Avatar
It doesn't work that way. Dealers can't fix what ain't broke.
I really wish people would quit posting these TSB lists, it just causes a lot of confusion and misconceptions. People see huge lists of TSBs, and they're like "Oh, that applies to my truck, I want it done!" No. You've gotta realize, a TSB above anything else is an educated SWAG by engineers further up the food chain, intended to streamline diagnosis and repairs. Half of these stupid bulletins don't even work the way they're intended to. Some apply, some don't, some work, some don't. It's up to your dealer to inspect and diagnose your truck to determine the best course of action for a 100% fix - the TSBs are best used as a guideline, not the gospel.
That said, yes, there are some dealers out there that suck, and won't address even a well known concern. To them, I dunno what to do, other than to try another dealer, or contact Ford Customer Service.
Old Nov 15, 2006 | 11:25 AM
F150 Duke's Avatar
Any info about this one?
I have an 05 that has a rattle that sounds like loose metal coming from the steering wheel column.
The Ford service department at my dealership said they think it's the aftermarket radio and are trying to charge $300+ for diagnosis (3 hrs at $100 per hour) and then a couple hundred to put in a new radio.
I mean you can drive the truck and blaintanly hear it coming from the steering wheel.
Duke
Old Nov 15, 2006 | 11:33 AM
marlin39d's Avatar
Glad my truck is not an '04-'05.
But I bet my 2006 will have a TSB or two as time rolls on!!! But @ 5600 miles all seems A-OK so far.
