Help with what I think is an ABS line???
Old Jan 24, 2006 | 09:00 PM
The_Brute's Avatar
Help with 4x4 hub line???
Edit: I posted this in the brake section because I thought it was an ABS line but I was wrong, it goes to my driver side hub.
Atleast I think that is what this plastic tube is. My question is what does it plug into??? It was just dangling right under the end of the air intake. I took a couple of pictures for reference. I thought it looked like maybe it plugs into the top of that brake booster or whatever it is with the hardlines running out of it. I pushed on it pretty hard but no luck. Can anyone help me out? Thanks.
Old Jan 24, 2006 | 09:03 PM
Quintin's Avatar
I dunno what the hell that is. Might be a vacuum line that'd go to the hubs on a 4x4. Ain't got nothing to do with the brakes though.
Old Jan 24, 2006 | 09:08 PM
The_Brute's Avatar
I tried to trace it down and it looks to go into a grommet of some sort and then runs down to the anti-lock brake sensor? No idea where it could plug into. I know I'm missing something here...
Old Jan 24, 2006 | 09:13 PM
The_Brute's Avatar
Ok, you are right Quintin. I retraced it and it does run to the hub, not the ABS sensor. Any idea where that thing should plug into? I don't see any other small hoses or anthing lying around under there... Thanks for your help.
Old Jan 24, 2006 | 09:15 PM
Quintin's Avatar
Is your truck two or four wheel drive?
Old Jan 24, 2006 | 09:24 PM
The_Brute's Avatar
It's a 4x4.
Old Jan 24, 2006 | 09:57 PM
Quintin's Avatar
Then I dunno where it'd go. I'll look at a 4x4 tomorrow and see.
Old Jan 25, 2006 | 07:45 AM
The_Brute's Avatar
Can someone with a 4x4 look at theirs to see where this plastic line plugs in? I'm not sure where the vacuum soloniod to engage the hubs is. Thanks.
Old Jan 25, 2006 | 10:49 AM
The_Brute's Avatar
Just for future reference. That line in my picture doesn't go to anything apparently. I stopped by my Ford dealership and popped the hood on a new 4x4. It had that same plastic line but it was just clipped onto one of the brake hardlines but it didn't run anywhere.
