Finally Lifted!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 19, 2006 | 10:31 PM
  #31
Josiah's Avatar
4.10's would bring it closer back to stock, but then you have the additional weight, I would definitely go to 4.56's, but thats another $1400 give or take a few hundred. The truck I test drove had pretty good low end, but at around 15mph you could really feel the loss in power. It felt strong in the lower rpms until I tried flooring it (which made no difference). You feel like you're on a throne sitting that high.
Edit:
It's about 1400, I've seen it as low as $1200 and as high as $1600. They have to do the front and back because you have 4wd, it's half that in 2wd's. If you only did one side, that side would spin faster than the other when locked in. Good luck.
Old Jan 19, 2006 | 10:34 PM
  #32
qball2439's Avatar
holy **** that's some coin for a gear swap. They sure are much cheaper over here in FL (where the trucks are level) j/k
Old Jan 19, 2006 | 10:38 PM
  #33
brypink2's Avatar
Originally Posted by KiCk *** FX4
how much $$ does that cost??
Depends on location, brand oF gears, etc...
I got my front and rear done for $1250.
Old Jan 19, 2006 | 10:39 PM
  #34
brypink2's Avatar
how much cheaper? (don't hurt your neck looking at my high front end) oops...j/k
Old Jan 19, 2006 | 10:44 PM
  #35
qball2439's Avatar
we have a couple 4x4 shops where it's $400 for labor (200 for the front, 200 for the rear) and if you like you can provide your own gears and oil (which I have done in the past). I guess it comes down to having a friendly shop in the area.
On a side note, why do you guys have fronts higher than the rear? Is it for front end clearance on dunes?
I couldn't run the front higher, I would be looking at the sky when I hooked up a boat.
Truck looks good man
Old Jan 19, 2006 | 10:56 PM
  #36
brypink2's Avatar
Labor is about right. The gears, unless you have connections to get them cheaper, are about $700 (front & rear). I paid a little more for 3yr/36k warranty labor (no questions asked) and lifetime warranty on the gear sets.
Yes, front end is higher for more clearance to help compensate for the engine weight. We pull toy haulers that weigh quite more than some boats...a weight distributing hitch and bag the rear you'll be fine.
EDIT: Thanks for the truck compliment!
Old Jan 19, 2006 | 10:59 PM
  #37
KiCk aSs FX4's Avatar
how do new gears compare to a tuner?? i kinda dont want to spend 1200 right now but a tuner sounds nice. Will that help my truck?
Old Jan 19, 2006 | 11:03 PM
  #38
fourpointsix's Avatar
Man the truck looks GREAT! You really have to do both the gears and tuner if you want to get the performance back. If you just do the gears your speedometer cannot be calibrated until you get a tuner. Ford's recalibration will not work with 4.56 gears (I already tried). I would drop the coin and do both. Your transmission and drivetrain will thank you. That's a lot more weight to be moved by too tall of gears. Once again, your truck looks great. Echoing Josiah earlier, we should have a NorCal meet and check out everybody's trucks.
BTW Rear End Specialists in Santa Clara=$1200 for a 4x4.
Old Jan 19, 2006 | 11:06 PM
  #39
brypink2's Avatar
I got a tuner (xcalibrator2)...I got it after the gear swap. I would think even with a tuner you still put a huge strain on your transmission and engine with the bigger tires and smaller grear ratio.
Old Jan 19, 2006 | 11:45 PM
  #40
jrbhc8's Avatar
I can't tell from the pic, but I'm sure it looks killer. Don't listen to what everyone else says. Your running a 6 in lift, 20's with 37's. Now that's an impressive setup where I come from.
jrbhc8
Old Jan 19, 2006 | 11:48 PM
  #41
sorry abou the sig. they are actually 18s on 35s. I will be getting more pics tomaro
Old Jan 19, 2006 | 11:53 PM
  #42
jrbhc8's Avatar
Still, a very respectable truck.
jrbhc8
Old Jan 20, 2006 | 12:14 AM
  #43
nitzer280's Avatar
That lift gives your truck an awesome stance!
Old Jan 20, 2006 | 12:32 AM
  #44
Josiah's Avatar
jrbhc8
I think they're 18's on 35's, not 37's on 20's, where did you get that?
Edit:
I see where, didn't realize there was a 2nd page (I have it set to view like 40 posts per page).
Old Jan 20, 2006 | 09:54 AM
  #45
jvernacchio's Avatar
Truck looks awesome! I love them in Black!
