Backup Alarm hates the cold.
Originally Posted by WaWaTuSi
My Backup Alarm hates the cold. Under 20 degrees and it will beep as soon as you put in in Reverse.....
Anyone else have this problem?
2006 fx4
2006 fx4
Nope cleaned em off and no change. Once the truck fully warms up or if its over 30 degrees its good to go.
Example.
Threw my hockey gear in the back and started the pig up.
Threw it in reverse "BEEEEEEEEEEEEEEEEEEEEP"
Went and got skates sharpenened (10 min drive).
Started it up and threw it in reverse again "beep, beep, beep, beep, BEEEEEEEEEEEEEEEEEEEEP.
Drove to the rink.... (1/2 hour drive)
Just to try it out threw it in reverse. Nothing.
Temps were like in the teens....
Started it up this morning (in the 30's)
Put it in reverse and no beeps...
It is def temp related.... How I do not know.
Side exit dual Flowmaster exhaust btw....
Example.
i know that my exhaust fumes will sometimes freeze to my sensors if there is enought moisture- only really happens at 20 and lower
jj
jj
Check behind the bummper and see if there are any wires that might be loss. Not even sure if that would cause that or not but it is something to check..
Where in NJ are you from? I also play ice hockey down in Wall..
2006 fx4
2006 fx4
It never gets anywhere close to that cold here.
even though I no longer have the F150, My mountaineer does the same thing in the cold. I make sure no ice build up is on them, but once I put it into reverse in the mornings, its nothing but a solid beeeeeeep!!
I ended up just turning it off for the time being so I can take a look at it later
