Best Oil
Mobil, AMS, Redline and Royal Purple would be the best among synthetics. I prefer Mobil because it is very high quality and readily available. I also choose to run a 5w30. A lot of it is personal preference...
Steve
Steve
Steve
Steve
As a proving theory, those who have had their rigs in the Dealer for a burnt out engine and had the Dealer say you burnt out the engine from use of the wrong oil, these are the owners who should heed better oil schedules. I have never burnt out an engine and do not expect to drive over 80K miles between buying a new rig. Those who go over 100K miles between trade-ins should heed better oil maintenance.
Use the recommended weight. Use something with the latest API rating. Use a good filter. Change it regularly. Sleep well at night.
FWIW, you may run into VCT problems further on down the road using oils thicker than what's recommended. I run Motorcraft 5W20 and FL820S filters.
So would most of yall say that 5w20 from mobile,penzoil,castrol is better then motocraft 5w20? I understand that i will get multiple answers about this but for me if i change it i want to put the best but im not near ready to start pumping in the 5 bucks a quart oil! lol!
Originally Posted by jimmy k
I always use Mobil 1 5w20 and started using a Motorcraft filter. Change it every 6,000mi.I figure if full synthetics are good enough for commercial jets, they should work OK for me.
Where are you getting 5w20 from? I checked at wal-mart and they don't carry it. Can you get it in a 5 quart bottles like some of the other weights?
5 quart jugs and single bottle cases.
I just re-read the post and realized you are looking for Mobile-1 in the 5 quart jug.
I had originally thought you were looking for Motorcraft 5-20 in the 5 quart jug.
Sorry for the confusion. :o
