edge splash screen
#47
#48
#49
The EDGE splash screens are 128 X 64 pixels and 1 bit per pixel monochrome (black and white) color depth. MS paint works with these pretty well. You can change the size using the "stretch" feature and increasing/decreasing the size until you get to 128 X 64.
#50
Originally Posted by afdt2
Jim/VMax,
I got it to 105x64 in .bmp format...I'd like to email it to you via the email address on your website...is this ok? You just put in the Edge\...\splash directory with the other .bmp's and it should upload.
#53
#55
Originally Posted by jims94vmx
can someone please send me the bmp file i need to do the vmax above...can't find the email i needed now that my 98se works. i tried loading the bmp file and kept getting black and white only or to big.....thanks.
Just right click the picture and save it. Open it up in the "Paint" program and save it as a Monochrome bitmap (bmp.). It is the correct size. I just gave it a try and it works.
#56
#57
when i do that it looses alot of the lines for some reason when it saves it as a monachrome bmp file....does not stay as bold.....any other thoughts?
Ya, I had that same issue with one that I made. I had to use the paint program to add and clean up some of the lines. I just played with it untill it looked right.
#58
I saved it as a monochrome .bmp, and then I had to make it a .gif to post. Therein lies the rub...I have a zip file with all the .bmps I made including the bike. I will email it to anyone who asks me via email.
Nates93sten AT comcast DOT net
#59
