Mark Lt Grill Installation
Old Jan 5, 2006 | 07:24 PM
niceasssupercrw's Avatar
I just bought a lincoln mark lt grill. i want to keep my surround chrome piece but i am having trouble removing it. I dont want to break the clips that hold it to the original grill....any helpful tips?
Old Jan 5, 2006 | 07:29 PM
ziggaboo's Avatar
use a screwdriver and pry em back very carefully and pop them out. i took the whole surround off the truck and did it inside on carpet so i didnt have to worry about scratching anything when i did my harley grill.
Old Jan 5, 2006 | 10:25 PM
SoundPer4mance's Avatar
the carpet thing is definately a good idea, just use a screwdriver to bend the lock tabs out of the way, and work your way around the grille. i accidentally broke a few tabs doing mine but it still works just fine!! let us know if you still cant get it! and post some pics, id like to see the chrome on chrome
Old Jan 6, 2006 | 01:40 AM
Indiana-red4x4's Avatar
Be very careful. I have done this a couple of times. there is no easy way to do it. All three that I have done took alot of patience. Hope it turns out ok.
Old Jan 6, 2006 | 01:51 AM
swhite005's Avatar
Pain in the a$$!!! I used a set of plier to clamp on to the stubborn ones
Old Jan 6, 2006 | 12:23 PM
inurok's Avatar
Dont worry even if a couple break it should hold tight.
Old Jan 6, 2006 | 03:21 PM
Tical84's Avatar
The pieces that break off are from the old grille anyways so if you don't plan on reusing it then it doesn't matter if you break them. You will still have all the clips on the LT grille to hold it to the surround but on the old grille there are something like 15 clips so even if you do plan on reusing it or selling it breaking off a couple wont matter all that much.
