E-Fan Fuse BLEW up...literally.
Old Jan 5, 2006 | 05:44 PM
Josiah's Avatar
Unbelievable. I have a hunch it was from mudding and water may have caused this, but it looks as if it could have caused a fire. Thought it was worth showing, I'm thanking my lucky stars for this. Any idea if anything else could have happened as a side effect from when this exploded, I hope my e-fans are ok.
Old Jan 5, 2006 | 06:45 PM
mountaineer02v8's Avatar
You beat the crap out of that truck all the time! If the trucks not going to blow up, somethign is going to! In this case, it was the fans!
Old Jan 5, 2006 | 06:54 PM
Originally Posted by RandallT
got it....
and if that is the case, then maybe he should take it up directly with him...........just my .02
Yeah, and not in other people's posts.
Old Jan 5, 2006 | 06:58 PM
Josiah's Avatar
Mountaineer, I don't know what your problem is, but ever since the thread about being pulled over, you were quoted as saying:
Mommy says it's time for daily feeding
Blah blah blah. You sure do act your shoe size. I have done nothing to you and even responded to your questions (What is SOHC, and what is the difference between the SOHC and the 5.4L?) in the Saleen F150 thread. Grow up big guy, quit speaking down on people.
Old Jan 5, 2006 | 07:05 PM
BREWDUDE's Avatar
Hey Josiah...stop beating the hell out of that truck
Just kidden bro...just take a look at the rest of the wires in that harness. As long as there not burnt further down the run , away from the fuse, Im guessing you should be fine. The fuse did its job...sorta...It shouldnt have exploded like that. I would fix it up and keep an eye on it. Maybe run it in the driveway for a bit to see if that fuse is getting real hot after a period of time. You may have a problem somewhere else.
But as you said, if you went off roading and got it all wet and nasty, that may have caused it.
BREW
Old Jan 5, 2006 | 07:36 PM
Matt 05'FX4's Avatar
Here is what happened......judging by the green on those connectors, the water sat in there long enough to corrode the connection. This corrosion became resistance between the fuse and the contacts. This resistance became heat as the current flows through it. The heat melts the connector and wallah, you have what you show in the pictures. I see this stuff all the time at work. I guess just cut that biotch off and put something water tight in its place. Glad it didn't catch fire!!
Old Jan 5, 2006 | 07:43 PM
gobra's Avatar
How can it catch fire if it's under water?
Carry a fire extinguisher with you young Josiah.. and get fire insurance for your truck too...
asinatra, you kill me.....
Old Jan 5, 2006 | 08:04 PM
ThumperMX113's Avatar
I love this website. . .
Old Jan 5, 2006 | 08:08 PM
tardman91's Avatar
I don't want to start any crap, but if I recall from one of your pictures of your install the wires looked as if someone threw spaghetti underneath your hood. I'm not sure if you cleaned it up or not, but maybe your problem wasn't so much the fact that water gets under the hood as it was a sloppy wiring job.
Old Jan 5, 2006 | 08:23 PM
kd4crs's Avatar
Some folks put a "FORDING" cut off switch in the main power line to the fans to cut the power to them when there is any chance of them getting drowned, like when fording a stream while out mudding about. Just don't forget to turn them back on.
Old Jan 5, 2006 | 08:32 PM
gobra's Avatar
FORD=
Fire
On
Relay
D'OH!!!!
Old Jan 5, 2006 | 08:38 PM
Josiah's Avatar
I cleaned it up shortly after those pics were taken, I was still trying to get them to work right at the time of those pics.
Brew, I hear ya, it becomes a muddy mess under the hood with that fan shroud out of the way now (you must do this to install the e-fans). The mud just gets everywhere with the gap going right to the ground.
Old Jan 5, 2006 | 08:42 PM
BREWDUDE's Avatar
Well since you have to put a new fuse holder and all in there, you should look into a marine grade one. Nice and water tight. Should keep it from happening again. Just run down to West Marine or would it be called East Marine on that side of the world...
BREW
Old Jan 5, 2006 | 09:35 PM
SSpiro's Avatar
BREW
I was thinking the same.
Old Jan 5, 2006 | 09:49 PM
RAYJAY25's Avatar
http://www.boatersworld.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&ca
Boatersworld Waterproof Fuse Holder $7.09
