Steering Column Shroud
Old Jan 2, 2006 | 07:47 PM
Gordon04's Avatar
I am having a terrible time getting the lower steering wheel column trim panel installed on my 2004 F150. I found some posts saying that removal/reinstall was a pain. The panel came out without too much of a hassle but does anyone have any suggestions/tips for re-installing it? I don't see how to get it back in there (specifically I am having an issue getting the "lip" back into it spot inside the steering wheel) without damaging it.
Thanks!
Old Jan 2, 2006 | 07:48 PM
Quintin's Avatar
You're supposed to pull the steering wheel to get the lower column cover in and out.
Old Jan 2, 2006 | 11:45 PM
SteveVFX4's Avatar
I remember an old trick that member Sandog53 said, here it is:
Originally Posted by Sandog53
Mike, the only trick I have your not going to like. Those tabs are a pain in the *** to get back in there. You can either take the steering wheel off, hold your mouth right and fight it for about an hour, or I just cut those two tabs off. Then it goes right on. I was showed that trick by a Ford Technician.
so basically you just cut the two tabs off on the lower cover and it goes right in.
Old Jan 3, 2006 | 01:39 AM
Kool Aid's Avatar
That's the way I did it.
Cut 'em off, and never looked back.
You can't even tell they're not there.
Old Jan 3, 2006 | 09:28 AM
ford2004F150's Avatar
I turned the wheel upside down... fits right back in.
Old Jan 3, 2006 | 11:37 AM
Deeve's Avatar
Turn the wheel upside down! Good idea, I will have to try it when I install my CA670. What tabs got cut off? I have not removed mine, so I am not familar with them?
Old Jan 8, 2006 | 01:43 PM
Deeve's Avatar
Tried the upside down steering wheel trick and it did not work for me. I ended cutting about 3/8" off the shroud and it fit like a glove! Thanks!
Dave
