Cruise Control not working....
Old Dec 27, 2005 | 03:00 PM
CHDS PNY's Avatar
a buddy of mine is driving back home from Christmas, he said his cruise control doesnt seem to be working at all
a couple days ago it was on and off...it would just shut off with no warning
he has a 2004 SuperCrew Lariat 5.4L....and is out of warranty...any information i could pass on to him would be great!
Happy Holidays!
Chad
Old Dec 27, 2005 | 03:13 PM
ChrisAdams's Avatar
Check for trouble codes, if none, suspect the switches on the wheel, as that is the entire cruise on the new body trucks. The switches send a signal, the PCM does the rest of the work.
Chris
Old Dec 27, 2005 | 03:26 PM
04NickySP2's Avatar
Check fuses? I'm guessing there is a fuse for the cc.
CHDS PNY's Avatar
Chris
and there probably isnt a way to do that w/o taking it to a dealer is there
Old Dec 27, 2005 | 03:34 PM
CHDS PNY's Avatar
he said he checked the fuses, he pulled it out and nothing was blown...what number is the fuse....maybe he didnt check the correct one
Old Dec 27, 2005 | 03:44 PM
ChrisAdams's Avatar
A bad fuse would be bad. It would not work/not work then not work. It would not work, period.
Assuming no one hase a tuner/scangage etc. You can go to most chain autoparts stores and they can read, usually for free, and clear codes.
You write down the code and post it if you get one.
Chris
Old Dec 27, 2005 | 03:51 PM
CHDS PNY's Avatar
Chris
i will have him do that and if i get a code, i will have him post it
thanks
Old Dec 27, 2005 | 06:26 PM
TysonsLariat's Avatar
The cruise control will go off if the parking brake is engaged. Check the switch for the parking brake, perhaps disconnect it and see if the problem goes away.
Old Dec 27, 2005 | 06:55 PM
ChrisAdams's Avatar
Dang, forgot about that one.
Also, be sure the brake lights are not coming on. A bad brakelight switch has caused a lot of cruise controls to be needlessly replaced.
Chris
Old Dec 27, 2005 | 06:59 PM
You guys are good!!! Brainstorming online rocks.
Old Dec 27, 2005 | 08:24 PM
Quintin's Avatar
Check fuses 14 and 16 in the central junction box, they're both 10A. Be sure that the brake lamps work, and that the parking brake indicator is working.
Old Dec 27, 2005 | 08:30 PM
CHDS PNY's Avatar
now he said it just started to work again
