shocks for 3" skyjacker lift
I was planning on buying the Rancho RS9000X shocks for the rear of my truck once I get the Skyjacker 3" lift installed, since it doesn't come w/ shocks. But I've been told on the phone by a salesperson for one of the companies I called to check pricing on the lift that the Rancho RS9000X shocks will not fit that application w/ the lift. They are made for 4" lifts (like the Rancho) or less than 3". Does anyone know a shock to recommend for my application? I want one similar to the Rancho, have considered the skyjacker platinum and the bilstein, but I want a monotube design.
The rear of the skyjacker kit only lifts about 1.5", the front is three. Still keeps a proper nose down pickup stance, just not quite as big a rake. So, the answer is to go with the Ranchos for an up to 2" lift.
You'll love the Skyjacker kit! You will need a spring compressor to install it, and a 2 3/16" socket (if I recall correctly, the kit spells it out) and a boatload of torque to retighten the front coilover, but the instructions are very good and it goes together easy.
Originally Posted by CrAz3D
I thought the RS9000s were adjustable for w/e lift you had...@ least I was quite sure.
I have the same kit, and I put on skyjacker hydro 7000's on. I couldn't ask for anymore. They ride and look great. I don't have so much of that rear end hop while going around a corner anymore. The skyjacker add-a-leafs raised my back up a full 2". I called skyjacker about the rear shocks and they gave me the part number that they recommed for this kit. Plus I wanted to keep it skyjacker all the way around.
This was at 40" before the lift.
