dual exhaust info/help
I am debating on what exhaust to get, I have always routed my exhaust out like an L. I would like a dual out the back set up but havent see too many 04-05 models with them. I have only seen 2 or 3 other newer F150s with them. I know there was a write up in the exhaust forum which was very helpfull, now I am looking for more pics and some more feed back on how they are holding up after time, do they stay level or do they droop over time. Especially the hangers that have to be hung on the drivers side. I ask because I have seen some others that tend to hang lower than what I would like, is there a way to modify this so they stay tight up or closer to the bumper.
Any info would be appreciated.
M V
M V
Originally Posted by cvc14
tardma...
u have a picture of your truck form behind to show off your exhaust? What tips are those?
Thanks guys for all the quick responses, I appreciate it
FX4andHarley,
sweet truck, great pics to. Did you install it yourself, I was looking through your gallery and saw the hangers, were they the ones included in the kit. What part number is your exhaust?
StainlessWorks.net has those Camaro style tips.
Thanks again
Later
M V
FX4andHarley,
Thanks again
Later
M V
Originally Posted by MyVersion
FX4andHarley,
Check out the following:
https://www.f150online.com/forums/sh...d.php?t=213027
No problems with drooping/settling here. Borla, Magnaflow, Flowmaster ... it's all good.
This has to be the hardest thing I've had to do on my truck. I can't make up my mind, they're is soo many choices. I just called a shop around town and they said they could do a Flowmaster with dual corner exit with slant cut tips for $325. Im just not sure how loud it will be, I really don't think I'd lose any bottom end either seeing how the truck has 4 cats. What do you guys think? I was also wondering about true duals? Anybody done it yet?
Originally Posted by FX4andHARLEY
Yes I did the install myself in my garage on jack stands. The part number for my truck is 16615 because I have a Regular Cab. I got the system from “hottexhaust.com”. Use discount code “fordtruck8” to get a big discount. The hangers are the ones that came in the kit, I just rounded off the corners then primed and painted them black for a cleaner look. Check out the thread “Lovin my Magnaflow” for more details.
Good Luck
Thanks again guys
M V
MyVersion:
i am from the boston area, a buddy of mine did the exhaust at his shop -
check out the pics here in my gallery -
https://www.f150online.com/galleries...w.cfm?num=8732
so far not a single issue with the setup. it is custom made pipe (y pipes and all) - and those are four stainless tips you see there 4"
