Brake controller location?
Old Dec 10, 2005 | 02:00 PM
cdestuck's Avatar
Ordered a 06 Lariat, which is to be built this week of the 12th. Has the Captians seats. Was wondering where you guys have been locating your trailer brake controllers. In my 2003, it had the nice little hole in the dash near my right knee for this. Wondering where you guys were doing this
Dan Stuckey
Altoona, Pa
Old Dec 10, 2005 | 02:11 PM
dlandis03's Avatar
Left side Inder the dash there is a metal plate, It almost looks like thats what its there for, if its not ment for it you coulda fooled me. Thats where I put mine. Fitment is perfect and I have never hit my leg on it. out of the way and easy to see. Give it a look.
Old Dec 10, 2005 | 02:17 PM
Cycleman6's Avatar
Yep! That's where mine is...I just kinda found it, works great and the controller is able to be level there also as that's important with many of the brake controllers like mine that are inertia activated.
Old Dec 11, 2005 | 12:59 PM
Daleford's Avatar
Question
Good to read this as I will be mounting one soon. I understand the wiring is already there for the controller to connect to. Where do I find this wiring in relation to that plate? Also, do I need an "adapter" harness to connect aftermarket controller to this Ford wiring?
Old Dec 11, 2005 | 01:05 PM
Tbird69's Avatar
The harness you get from Ford has a connector on one end that plugs into the stock wiring, and is bare on the other end. just follow the wiring diagram and you should be able to connect any controller no problem.
BTW Ford also supplies the relay to make it all work.
Old Dec 11, 2005 | 07:43 PM
Daleford's Avatar
Thanks. Do you know what that wiring harness costs in CAD$
Old Dec 11, 2005 | 11:19 PM
nvrenuff's Avatar
If you got the tow package, then you already have it. It will be in a clear plastic bag either in the glove box, or one of the door compartments. The supplied relay you will need is in the bag too. It plugs in to the fuse box on the passenger side floor kick panel. By the way, I mounted my controller under the dash, drivers side, between the programming port and the center console as well.
Old Dec 12, 2005 | 12:13 AM
Newt's Avatar
I mounted my Prodigy on the left.
Old Dec 12, 2005 | 04:41 PM
osbornk's Avatar
I also put my Prodigy there. I figured it must be meant to be there because I couldn't figure any other reason it was there.
Old Dec 12, 2005 | 05:06 PM
Daleford's Avatar
Ah ha. That is what that little bag of goodies is for. So I simply put the relay in the fuse box and power is supplied to the controller? No more running a wire thru the dash to the battery like the old days?
Old Dec 12, 2005 | 05:53 PM
SAJEFFC's Avatar
Actually the power for the controller and the electric trailer brakes comes in through the harness you plug in under the dash (supplied in the bag). The relay you plug into the fuse box sends power to the trailer battery charge wire in the 7 pin trailer plug in back. That way your trailer battery will charge when your plugged in.
Old Dec 12, 2005 | 08:24 PM
Daleford's Avatar
Thumbs up
OK I think I got it. I looked closer at the bag of goodies [4l3t-15a416-a]
and looks like everything is there including instructions. The bag had been opened [this is a used truck] but harness unused. thanks
Old Dec 21, 2005 | 07:29 PM
ajhf150's Avatar
I just picked up my 06 FX4 a few days ago and want to mount my Prodigy brake controller. I do not see any metal plate under the left side of the dash. There is the parking brake and the parking brake release, but no metal plate???
Old Dec 21, 2005 | 09:22 PM
nvrenuff's Avatar
It is on the left side of the center console, between the program port and the center console. Can't miss it.
Old Dec 21, 2005 | 10:18 PM
Newt's Avatar
Ford must be changing their usual crap. Mine is between the steering column & the emer brake.
