What else can be done??
Old Dec 9, 2005 | 01:05 AM
gmanjerseyfx4's Avatar
I got my procharger on my truck a few weeks ago and i love the power its making...i love it so much i want more!!! (who doesn't?) So what i am asking is what else can be done to these 5.4L 3V engines?? Forged pistons? Cams? Heads? What else is out there that will produce more, if anything??
Old Dec 9, 2005 | 01:07 AM
fourpointsix's Avatar
Before you do that, put on some headers and true dual exhaust. Is your truck custom tuned? Do that too! BTW, how fast is she runnin'?
Old Dec 9, 2005 | 07:54 PM
bushtree's Avatar
Full exhaust system,
Custom Tunning,
Electric Fans,
Change gears,
Then change out the engine internals to strong parts and throw on a Larger Intercooler and Up the Boost!
Old Dec 9, 2005 | 08:09 PM
nuclearthreat54's Avatar
bigger MAF?? new injecters....hmm......ya well most of its been said already
Old Dec 15, 2005 | 10:10 PM
khendrix2374's Avatar
DUnno about pistons.. Ive been looking into that... But, the Lincoln Navi's have 4 valve heads.. maybe someone could comment about swapping those heads over to the 3 valves..
Cams. Who knows... I dont think anybody is ready to put cams in yet.
Post it up if you find anything out.
I thought I read a post a while back about forged pistons, rods, and lifters but I cant find anything now.
Old Dec 15, 2005 | 10:17 PM
Motorcraft fuel injectors for the Supercharged Cobras will fit out trucks... Dunno any part #s..
Here are some.. dunno if they fit either. Fuel Injectors
Did you not get new injectors with the ProCharger?
How is the high RPM range? Is it leaning out?
Any problems?
Did you upgrade to a new fuel pump?
How much boost? another guy was running a 12# pully on his '04 Procharged truck.
Old Dec 16, 2005 | 02:03 AM
Josiah's Avatar
Mind timing your 0-60 for us Use the counter in the message center if you have a Lariat (Fx4's might have them as well?). Thanks.
Old Dec 16, 2005 | 02:43 AM
Kool Aid's Avatar
Gears!
Rear end gears!
:santa:
Old Dec 16, 2005 | 12:18 PM
asinatra's Avatar
Thats lame, might as well use the cd player track time.
Old Dec 16, 2005 | 01:29 PM
Ford Man Dan's Avatar
I'm not familiar with the procharger set up. Do they come with intercoolers? If it doesnt come with an intercooler I would deffinitely get one. After installing that, I would do a true dual exhaust set up. After exhaust, get a custom tune and change the pulley system. Maybe run around 8-10 psi. When i say get a custom tune, dont order a tune from someone in a different state...Doing that is absolutely pointless. You need to tune that truck on a dyno. You have to remember every truck is different, so buying a tune from someone else isnt exactly going to be the best for you.
Once I complete all these mods on my Roush set up, I should be pushing out more than 400rwhp at my elevation, which is around 6,000ft.
You have to remember, once you get all that power you are going to have to figure out how to put that power to the ground, which might include getting some et street tires and doing some suspension work.
