Engine Blew 05 KR
Engine Blew 05 KR
Well, last Saturday the wife and I got a babysitter and headed out to dinner in my 05 KR. We got about 3/4 of a mile when the engine started shaking, idling rough, and lost all power. I thought it was a PCM error; we turned around and limped it home. As soon as I got it in the garage it started knocking. I shut it of immediately. We took the wife Expedition to dinner with hopes that a PCM reset would solve issue. On Monday the Ford dealer pick up my truck and hauled it to the service dept. On Tuesday they notified me that the engine was toast and I should come over and take a look. When I arrived they showed me the engine hanging on the cherry picker, pan of and dripping oil. The tech handed me a flashlight and said check out cylinder # 1. To my dismay the rod looked like an "S".
The tech explained that the injector had stuck wide open and hydro-locked the cylinder. The damage... bent rod, broken piston skirts, damage to the front counter balancer, and shattered piston.
The dealer had already ordered a new engine, which will be here Friday due to the holiday. But to my great surprise, they said the truck would be ready for pick up Friday afternoon.
Hey guys, whats with these injectors sticking open?! Could they be causing our rough idle and is there a way to check these injectors? My concern is a damn injector sticking open at 36,001 miles and we have to flip the bill for a new engine. If this is a common problem it needs to be addressed.
I've read of this concern on Ford's dealer message boards, but I haven't seen it personally yet. I haven't heard of any identifiers or commonalities with engines that blew up 'cause of this either. Doesn't sound good in any case.
I had my #8 injector stick open on me on the interstate with cruise on. I didn't notice a problem until I was slowing down for a off-ramp, which is when the CEL came on. The truck had about 5000 miles on it. I pulled it into a dealer in the middle of nowhere and they found the problem. They also advised there was a TSB that told them to replace the injector, all 8 plugs, and change the oil. When the truck stated shaking, almost wanting to kill, I only had 2 limp it about 2 miles to the dealer, so no other problems resulted of this stuck injector. No problems since then. The tech that worked on my truck said he only ever saw this happen on one other expedition 5.4L.
-Mine is a 5.4L
-Mine is a 5.4L
Originally Posted by extremeford4x4
Bad injectors will definitly cause a ruff idle.I guess that's a sign for bad things to come.
Originally Posted by hmfic
I had my #8 injector stick open on me on the interstate with cruise on. I didn't notice a problem until I was slowing down for a off-ramp, which is when the CEL came on. The truck had about 5000 miles on it. I pulled it into a dealer in the middle of nowhere and they found the problem. They also advised there was a TSB that told them to replace the injector, all 8 plugs, and change the oil. When the truck stated shaking, almost wanting to kill, I only had 2 limp it about 2 miles to the dealer, so no other problems resulted of this stuck injector. No problems since then. The teck that worked on my truck said he only ever say this happen on one other Expedition 5.4L.
-Mine is a 5.4L
-Mine is a 5.4L
Originally Posted by ChrisAdams
Have all the stuck injectors been on 5.4s?
They don't use the same ones as the 4.6, do they?
Design flaw?
Chris
Design flaw?
Chris
Originally Posted by fourpointsix
Yikes. The 4.6 is looking better every day the way things are going!
