Off-roading in a 2wd?
Old Jan 19, 2006 | 12:22 AM
  #31
Josiah's Avatar
As for getting stuck in 2wd, I drive a lot in the mud in 2wd and as soon as I feel I'm about to get stuck, I slam it into 4hi and reverse out. I've learned my lesson after nobody could pull my 6,000lb *** out the other weekend. I hang out with Jeep's :X
Old Jan 19, 2006 | 10:02 AM
  #32
04NickySP2's Avatar
The 87 saw 4Lo many times but mostly in the hole we nic-named the pine tree hole and at the local mud bog. She never made a complete run in the bog but did make it all the way to the end where she could not pull the rear end out after 185ft of mud madness. She didn't need 4wd for the normal play stuff but it wasn't a stock (8" suspension, 3" body, 39.5" Swamper Boggers, 4.56's gears, heads, cam & intake for the 351W) truck either.
I have yet to take my 05 offroad because I'm unfamilar with the local spots in my area. One of the biggest advantages I had when I was younger was I knew the area and I knew which hole would go from light to heavy mud.
You should be able to do fine with a 2wd just don't take any chances and pay attention to what is going on around you with other trucks. I found it helpful to sometimes just drop down in one side of the rut to gauge how deep things are going to get. Always bring a friend and invest in a good tow strap (not a chain) if you plan to go very often.
Old Jan 19, 2006 | 01:01 PM
  #33
vader716's Avatar
Well I took my Lariat off roading in some pretty rough terrain. Some mud, rocks, climbs, ditches, standing water, creeks, etc. The trail I went on said ATV or 4x4s only. I didnt take pics while on the trail (my mistake) but I thought it was pretty rugged.
I got through 90% of it in 2WD. I could have made it through with out 4wd when I used it but I figured why bother.
You can see the aftermaths (muddy lariat) in my gallery.
Old Jan 19, 2006 | 01:36 PM
  #34
twstd02's Avatar
Originally Posted by ThumperMX113
I usually off road in 2WD unless things are real nasty. The only thing is these trucks are very heavy so if your in soft sand you better keep your momentum up and don't turn too sharp.
Word.... ......when ever I take my truck to the dunes, mountain trails, or up to the snow, I hardly ever use 4wd. I have NEVER been stuck! I that it was 10x's more fun in 2wd than 4wd!!!
Old Jan 19, 2006 | 01:38 PM
  #35
Josiah's Avatar
Hey, we have that same brown stuff here!
Old Jan 19, 2006 | 01:42 PM
  #36
vader716's Avatar
have fun cleaning it? It took me days, sprinklers for the undercarriage, wheel removal for the brakes...hours and hours of work but it was fun.
Old Jan 19, 2006 | 01:43 PM
  #37
twstd02's Avatar
Originally Posted by countrygirl5.4
go gators! anyways... my story time! i had my 2wd out in a wet (looked to be level) field and was whippin it around a bit when my front end sank down a little too low and my *** end just started slippin/ no traction Needless to say... all my 4wd buddies were at work. I was stuck in the middle of nowhere! YAY! while walking in the rain down random unpopulated roads, I found some guys fishing that had a 4wd chevy! SCORE! come to find out... his 4wd wasn't working! haha MY LUCK! he ended up getting me out after a couple of good jerks with a tow strap and logging chain... in the mean time almost getting stuck himself and throwing about 4 inches of mud all over my truck! I loved the looks I got when I pulled into the carwash! hahaha
*wishes she had 4wd/ yet happy she doesn't*
assess the situation properly, i wouldn't suggest going out in the rain... keep to dry stuff when your by yourself!
Old Jan 19, 2006 | 01:54 PM
  #38
vader716's Avatar
Originally Posted by twstd02
what a perfectly good waste of truck sheet metal
cant even get over a speed bump....
Old Jan 19, 2006 | 04:56 PM
  #39
twstd02's Avatar
Its a thing called "Air Suspension" here is my old truck, I drove it in and out of driveways, over sppedbumps and pot holes in the road and everything. all the air bags aired up, it lifted up to about stock height.
Laying Frame, and supercharged with 3-15" subwoofers
Old Jan 19, 2006 | 05:01 PM
  #40
Josiah's Avatar
How many times were you pulled over driving that thing (honestly). My buddy with the 22's in my gallery (white lowered chevy), must smell like donuts. He has 6 tickets and is always the one the cops go after if he's racing someone. It happened once when I raced him. It was myself, a beater rx-7 and him, cops went his way and pulled him over, we weren't even followed. I have a feeling things will change when I lift
Old Jan 19, 2006 | 06:23 PM
  #41
KSUWildcat's Avatar
The only thing a 4WD is good for is getting you into more trouble farther in the hole than 2WD, HA!
Old Jan 19, 2006 | 07:51 PM
  #42
UberDude's Avatar
o sweet jesus he said N.O.S CRAP!
Old Jan 21, 2006 | 02:52 PM
  #43
leveled05STX's Avatar
I have gone off roading in my 05 two wheel drive. If things get too bad air down to about 5 psi and you can go almost anywhere. Also it does help with the limited slip.
