Underhood Insulation
Old Oct 28, 2005 | 02:35 PM
anaheim's Avatar
Originally Posted by bluejay432000
I noticed when I bought mine that it was not there, but the truck is so quiet, I do not see how it could help any.
I was under the impression that that material is not for deadening sound, but for fire protection, if the engine catches fire, it melts the plastic gromments holding it to the hood and the material falls on the engine to aide in putting it out.
Old Oct 28, 2005 | 02:39 PM
I see, never thought of that. Just always thought it was a sound dampner.
Old Oct 28, 2005 | 03:24 PM
jcc's Avatar
jcc
i dont think it would help put a fire out when there is gasoline involved just my 2 cents
Old Oct 28, 2005 | 03:26 PM
anaheim's Avatar
When i originally bought my truck, thats just what the salesman told me.
Old Oct 28, 2005 | 03:35 PM
jcc's Avatar
jcc
i just dont think it would work very well. if your engine compartment catches on fire i dont think it would really do any good if the flame went down the fuel rail under the truck
Old Jun 28, 2011 | 06:10 PM
mkinttrim's Avatar
Starting this up again, I'm going to order the insulation ( moving to alaska soon, need to keep some heat in there ). For those of you that do have it, how many clips to you have holding it in? Talked to Josh at Tasca and he doesn't know how many it takes but he has them in stock.
Old Jun 28, 2011 | 07:33 PM
Let us know what you find out.
Old Jun 28, 2011 | 07:36 PM
mkinttrim's Avatar
Will do, I have the part numbers for both. Josh said the clips are 94 cents a piece but I can get 50 on ebay for $7.95. I asked him to open up a box for the insulation to count the holes, haven't heard back yet.
Old Jun 30, 2011 | 09:56 AM
mkinttrim's Avatar
anyone?
Old Jun 30, 2011 | 11:01 AM
Windsor's Avatar
If your truck has that rubber strip that runs along the top of the radiator support, I think there might be 4 more clips beyond reusing the ones you already have. You should be able to see the holes in the hood support. If the holes aren't there, you're going to have to drill them.
Old Jun 30, 2011 | 11:14 AM
mkinttrim's Avatar
I count 16 holes in the hood that could be used for the insulation ( including the clips for the rubber strip ). I doubt if Ford would make 2 different hoods but stranger things have happened.
Old Jun 30, 2011 | 02:03 PM
Windsor's Avatar
I'll check mine this evening. I agree on the different hood, but some holes may not be used for the insulation too. I had to remove the insulation to put it on my Saleen hood sometime back, so my memory may not be that good.
Old Jun 30, 2011 | 02:08 PM
mkinttrim's Avatar
Ok appreciate it, found a place in california that actually has cheaper prices than Tasca
