Warranty Info/Help
Old Oct 27, 2005 | 05:23 PM
MyVersion's Avatar
Warranty Info/Help
I want to mod my truck, but I also got an extended warranty. I talked to my salesman (who talked to a manager) to see what I can and can't do. He said whatever is on FordAccessories.com is what I can do. Or if I buy through the dealer then it would'nt void it but would only cover 12 months instead of the extended period (that I paid for). He also said I can install any Roush products and it would be under the same 12 month warranty period. This was from some manager of the dealer. I just find that to be odd, seeing all of these modded trucks on the streets. What's the deal. I NEED HELP, any and all info would be greatly appreciated.
Later
M V
Old Oct 27, 2005 | 07:54 PM
expy03's Avatar
By law only the part you modded can be denied warranty coverage. If you mod the exhaust, Ford will not cover. the same as the intake, or any other mod. If you blow an engine, Ford may try to say it was the mod that did the damage. If you don't mod the tranny or rear end, Ford can't deny a claim, UNLESS they can prove the engine mods caused the tranny to go bad. Get my drift. A search will give you some more detailed info about the law on this. good luck
Old Oct 30, 2005 | 07:41 PM
MyVersion's Avatar
Thanks for the info expy, do you happen to know if this is in writing. I am a little hesitant to do any mods. I dont have the best of luck.
Later
M V
Old Oct 30, 2005 | 08:06 PM
FX4&EXCURSION's Avatar
Later
M V
It's the Magnusson Moss Act passed by congress essentially states that a manufacturer must PROVE that an aftermarket part caused the failure of an OEM part before they refuse to cover the OEM part under warranty. Here's a couple of links for info.
http://www.ftc.gov/bcp/conline/pubs/...#Magnuson-Moss
http://www.sema.org/Main/SemaOrgHome.aspx?ID=50100
Old Oct 30, 2005 | 08:54 PM
asinatra's Avatar
All service drives hate tuners. Everything else can pretty much slide.
Old Nov 2, 2005 | 06:29 PM
MyVersion's Avatar
Thanks for the links FX4, I appreciate it and I am relieved.
Later
M V
