Volant Cold Intake Wow
WELL JUST INSTALLED MY NEW VOLANT COLD AIR INTAKE ON MY 5.4 LARIAT SUPER CREW 4X2. GOT IT ON EBAY FOR $255 SHIPPED! GREAT BARGAIN I THINK. INSTALLATION TOOK ABOUT 25 MINUTES... THIS THIS SOUNDS AMAZING..GAS MILAGE IMPROVED I WAS GETTING ABOUT 19 MPG DOING ABOUT 70 ON THE HIGHWAY COMPUTER IS READING 21.5 NOW.. VOLANT KICKS ***....ONLY COMPLAINT UNDER WOT IT'S A LITTLE LOUD.. BUT HEY IT SOUNDS LIKE A MEAN MONSTER COMMING DOWN THE ROAD!
Do you have pics?
I've searched and searched but have yet to find the Volant on a 5.4 3V '04 or greater. I'm curious what it looks like installed.
I had Volant on my F150 2000 Lariat Scab and fit and finish were impeccable. Performance gains were formidable and it looked a million $$$'s. I was sold after this.
I'm just curious to see how it'd look under my '05 Lariat Screw. I know the two engine compartments are totally different in appearence.
Also . . .
I read on a past Troyer post that the Volant was causing the engine to "run lean." Has this since been recified by Volant? I really want to purchase the Volant but not under these conditions. I'm not a fan of the flashy one's like Airaid, K&N 77 series, AF1 and whatnot. I've always enjoyed the "stealth" look under the hood.
Also . . .
grubrunner do a search on Volants alot of very happy people have them . Dont remember a member saying they had a lean run, but do remember the airraids and some af1's mentioning that . As long as supplier gets the bug out thats the main thing .
grub there are threads on all the air intakes from lean burn . All have been corrected by this time hopefully. My opinion is i would put a Volant on mine when im ready. It is a true Cold Air Intake bringing air in from the outside of the engine compartment . Not with a seal against the hood in side the engine compartment.
Originally Posted by Grubrunner
I'll try and find the thread where Troy said the Volant (among others) was making the engines run lean. I'm just wondering whether this problem has been addressed by Volant.
Thanks.
Thanks.
Thanks for the reply fellas . . . it's what I wanted to hear. I'l go ahead and order my Volant in the coming weeks/months.
Any Volant pics would be appreciated. Somebody surely must have one in their gallery, right?
Running lean is in reference to the air fuel ratio. In Closed Loop, the PCM is using the feedback from the oxygen sensors to constantly adjust the air fuel ratio to a 14.64:1 A/F ratio. Open Loop is when the engine makes its real power. In this mode, the PCM ignores the feedback from the oxygen sensors and no longer forces the engine to run a 14.64:1 A/F ratio, instead it uses the signal coming in from the MAF meter or MAS to determine how much fuel and timing to put into the engine, based on hand-coded values in lookup tables. Some aftermarket intakes could force the engine to run dangerously lean in Open Loop
Originally Posted by aquaholic5.4
sorry guys been bust getting ready for hurricane wilma. i'll take some pics.. it looks amazing under the hood. Quick question &ignore my ignorance,,, whats runing lean mean?
To much gas not enough air = running rich
