Back to the rattle
Old Oct 11, 2005 | 10:48 AM
bob800's Avatar
Back to the rattle
My o4 rattles at start up, sometimes really loud turns heads and not in a good way, had it to the dealer they claim its normal for a deisel maybe they said ford didn't want them to fix it. they said its the cam phazer anyone else have this problem?
Old Oct 11, 2005 | 11:16 AM
svermill's Avatar
My neighbor sure as hell does!
Old Oct 11, 2005 | 11:21 AM
rutherk1's Avatar
Its a diesel? Your sentence was hard to follow.
Old Oct 11, 2005 | 11:39 AM
ziggaboo's Avatar
i've been trying to get a reasonable answer from dealerships as well. to be honest with you... they've been jerkin me around about it. 'its normal' my ***. they replaced my right cam phaser and its still doing it. could possibly be chain tensioners as these motors' cams/cam phasers are chain driven. these chains depend on oil pressure to build up tension. what you and i (what i believe) we are hearing, is that lack of tension. Now, unless there is a fix for it, or maybe there is a way to tighten it up or get pressure earlier i dont think the dealers are going to be able to do anything.
Old Oct 11, 2005 | 11:45 AM
Austinite's Avatar
Do you have a 2004 F150 or F250? If you have an F150 and your dealer is telling you that you have a diesel, you might want to try the next dealer. If you do have an F250, first of all you are in the wrong forum, and 2nd that sounds normal to me. Diesels are just loud and rattling sobs at all times.
Old Oct 11, 2005 | 11:47 AM
ziggaboo's Avatar
im assuming his motor sounds like a diesel on start up... but i could be wrong? thats what my last post was about.
Old Oct 11, 2005 | 02:04 PM
bob800's Avatar
f150 5.4 just sounds like a diesel on start up, the thing is not all of them do it just some, and why did it start doing it after 10000 miles just on day it started and hasn't quit just gets louder
Old Oct 11, 2005 | 03:14 PM
ziggaboo's Avatar
ive been told that it could be an oil issue as well. what kind of oil filter and oil are you running. i can def. tell that when motorcraft is in my engine its quieter.
Old Oct 11, 2005 | 04:50 PM
ThumperMX113's Avatar
Wow. . .
Old Oct 11, 2005 | 05:12 PM
Rich04F150's Avatar
Mine does the same thing. Only lasts for a split second at start up. And only does it after sitting for several hours. Sounds like valve noise to me. The dealer says it's 'normal.' I disagree, but what you gonna do?
I have noticed that it gets better when I get the oil changed. Maybe something to do with the anti-drain back valve in the oil filter?
Anyway, I guess run it hard and blow it up, OR deal with the noise.
Old Oct 11, 2005 | 09:40 PM
bob800's Avatar
When one pays that much for a truck you should have to deal with it...
Old Oct 12, 2005 | 12:15 AM
ChrisAdams's Avatar
Those with the rattle, may I ask what oil and filter you are using?
Chris
