nitrous question?
Originally Posted by RamSS/T
Well to answer your second question...a "50 shot" is about 50HP...and a "150 shot" is about 150HP and so on.
The first question depends on the size bottle...the concentration of the NOS (temp determines this)...and a few other things. But to give you a short answer, the best I can remember a 8lb bottle would last about 45 to 60 seconds with a 150 shot. Like I said thats the best I can remember...but I never sprayed it for more than 10 to 12 straight seconds at a time and then you would have to purge it before then next run and so on, so a lot was waisted.
The going rate around here is about $6-10 /lb. As for the amount of time as stated earlier of 45-60 seconds, especially a 150HP shot, you will never hold it for that amount of time consecutively, you will overheat. The autometer temp gauge in my mustang climbs quite rapidly in the 1/4 mile with only a 100 shot.
15 seconds MAX at a time
Bottle refills here are like $1-2/per lb
Dry Shot vs Wet Shot, wet shot will have the most impact and hardest "hit" when your on the juice.
When using a "XXX shot" you will most the time see a larger increase in torque (20+ more than the shot number you used depending on the install)
im assuming a wet kit would be harest to install since you have to go through the injectors? how exactly do these kits hook up? a line from the bottle to some kida controler in the engine bay that wires to a swtich thats controlled in the cab. i guess with relays so that it only works are wot? then from the controler to what? the fuel lines?
I certainly didnt mean he could use it for 45-60 at a time...I meant thats about how long a bottle would last me total when I was spraying a 150. In other words 4 or 5 passes.
wet, dry ? you all forgot one more powerfull nitrous sytem, direct port. My dad just installed it on his srt-10 and it is awesome but only lasts for a certain time [which isn't very long], in my opnion nitrous are only worth the cash if you either have a race car or a very fast car in thr firsr place. The truth is f150's are neither and far from it, even with a 50 shot the truck would only run high 15's and would still not be able to beat most cars and trucks on thr road.
Don't get me wrong people, nitrous is def the way to go on performance but it is not something i personally would not do to my 6000lbs truck that runs in the 16's.
thanks sounds pretty simple. one more question tho. even with a wot switch that doesnt mean it turns on everytime i go wot does it. and can i have it set up where the i push a button to spray but have to have a switch on for the button to work? ( dont want any accidents)
Now when tps reads 100%, the rpm range is between 2500-5000 and the switch is on; the nitrous is SPRAYING.
Next example would be i am accelerating over 2500rpms, the switch is ON, but tps doesnt read 100% i wont be spraying. It needs all three to complete the circuit. So if the switch is off, but i am over 2500rpms and at 100% tps i wont be spraying.
Wet kits are usually installed after the TB. Dry kits are normally installed, pre or post MAF (before the TB).
Nitrous is like a hot girl with an STD. You know you want to hit it, but you are scared of the consequences.
I think nitrous would be a lot of fun but it kills the resale value of the truck, but if you plan on keeping it forever then go for it.
I had a buddy with a GTI blow his motor using nitrous,
I dont want any std's.......
Please, **** resale value and an attempt for an excuse not to use it.
