is there any fix to the bed shakes?
Old Oct 1, 2005 | 10:53 PM
xwerx's Avatar
i have a 05 fx4 that has a "dancing" bed on it when i hit bumps. i have read some threads of people going to the BBB and such, but for what? what was the problem that made ford replace your truck? have noticed some other f150's on the highway that shake also. dont know if its a characteristic of a pickup or just the new f150.
Old Oct 2, 2005 | 12:27 AM
kd4crs's Avatar
I put an Undercover on mine and it cured "the shakes".
P.S. The bed extender helped some too.
Old Oct 2, 2005 | 01:07 AM
Chris3577's Avatar
I just bought my first truck and I have a 05 F150 XLT with a plastic bedliner and the truxedo cover on. What is the undercover? How much, and since it dont bounce, will it stop from scratching the bed up and rusting?
Thanks for the info!
Chris
Old Oct 2, 2005 | 01:20 AM
kd4crs's Avatar
It is a hard plastic bed cover. Here is the link: Undercover information.
Old Oct 2, 2005 | 08:35 AM
tardman91's Avatar
I noticed my bed dances too. Is that a common problem?
Or is there something the dealer can do to fix it?
I just figured it was normal.
Old Oct 2, 2005 | 08:42 AM
faawrenchbndr's Avatar
Chris,
The liner WILL remove paint from your bed. It happens just from the small vibrations and expansion/contraction of the liner. If you are concerned, but like the drop-in liner, just remove and touch up the bed once a year. The best thing would be Rhino or Line-X.
Old Oct 2, 2005 | 10:17 AM
Chris3577's Avatar
Originally Posted by faawrenchbndr
Chris,
How big are the spots where the paint is missing in the bed? I know the dealer has touch up paint, but those little bottles can not be used to paint the bed? How would you go about getting matching paint in a like a quart?
Thanks,
Chris
Old Oct 2, 2005 | 10:22 AM
ToddziLLa's Avatar
I've only had my UnderCover on for about 24 hours now, but I concur, it did drastically reduce the shakey-shake-shakes of my bed. :o
Old Oct 2, 2005 | 10:30 AM
worland's Avatar
It's the tail gate making all the noise when you hit a bump. A bed liner, bed rug or Line-X will quiet it down.
You know, I had a Ford factory bed liner put in my 97 F-150 when I bought it in 1996. When I finally pulled the liner out in June 2005, the bed was in perfect condition. No scuffs or rubs on the paint at all.
Old Oct 2, 2005 | 10:40 AM
eharri3's Avatar
Not all plastic liners are that bad.
YOu have the factory ones and the high quality after-market ones that fit snugly with no 'play', that sometimes also have features like extra padding or velcro fasteners underneath the keep them firmly in place.
And then you have the cheap crappy ones that have a poor fit that gives the space for more vibration.
Old Oct 2, 2005 | 08:56 PM
inbred's Avatar
This old thing again. Your problem is a dancing frame, not a dancing bed. Your bed is bolted solidly to the frame. Your cab is isolated from the frame with rubber mounts that help provide your smooth ride. The bed is not isolated however, so every movement of the frame equates to a movement of the bed. Because of its isolation, your cab is moving at different rates than your bed. Have someone drive your truck while you sit in the bed, and you will think your cab is going to shake itself off.
Why do things like covers and bedliners reduce the shake? add weight to the back end, and the rear of the frame will bounce around and twist less.
The outboard rear shocks tend to make the rear of the frame have more side to side action than normal trucks.
Just the nature of the truck's design. If you had a bouncier ride in the cab, as well as lower top rails on your bed, you would see 'shake' comparable to other trucks.
Old Oct 6, 2005 | 11:54 PM
nelson1each's Avatar
Just fyi. I have rancho shocks now, setting is five. Doesnt shake as much. Didn't bother me in the first place though.
Old Oct 7, 2005 | 12:04 AM
ThumperMX113's Avatar
If a bed cover helped cure the shakes, wouldn't a tool box also help?
Old Oct 7, 2005 | 12:40 AM
gotshot's Avatar
I took my 05 screw back to the dealer and complained about the shakes. Ford has a tsb out about them. They put on a dampener on the frame and it did quiet it down quite a bit. The service mngr. said that any weight back there helps also loke bed extender or something like that. I had a discussion about this about 6 weeks ago in the other body forum.
