tires and a lift. what kind?
Old Sep 24, 2005 | 12:10 AM
madtrucker's Avatar
i have an 04 2wd supercab f150. what is the smallest lift i can get to fit 35" tires? also what kit comes with a bigger lift in the front to level it out?. any info would help. thanks guys
Old Sep 24, 2005 | 11:12 AM
wandell's Avatar
You may be able to fit 35's with a 3 inch body lift or 3 inch Skyjacker, but it will be close. The 6 inch Fabtech and Pro Comp kits, and most others come with a lift block to level the rear of the truck.
Old Sep 24, 2005 | 12:23 PM
wakebordlf's Avatar
i have a 3" body plus leveling kit, and i still had to trim for 35's (thats on a fx4 i can imagine on a 2wd)
Old Sep 24, 2005 | 02:57 PM
AKFX42004's Avatar
I have 35x12.5R18 with just a 2 inch leveling kit and have not rub and no cutting
Old Sep 24, 2005 | 11:53 PM
madtrucker's Avatar
nice looking trucks guys. thanks for the info and the brand names.
Old Sep 25, 2005 | 12:39 AM
-TXF150-'s Avatar
The reason you have no rubbing is because you are using the stock FX4 wheels, but to answer your question honestly it all depends on the backspacing of the wheels you choose. I had to do some trimming even on mine with a 6" fabtech lift. What ever you do, im sure you will be happy with the 35's.
Old Sep 25, 2005 | 09:32 AM
wandell's Avatar
Exactly. The wheel width and backspacing are as important to fitment as tire size.
