front jack points
Old Sep 23, 2005 | 07:26 PM
scorpio333's Avatar
front jack points
I'll probably get slammed for asking, but I couldn't find an answer through searching. I've always used the front crossmember as a jack point to lift both front wheels with a floor jack then placing jackstands under the frame. Never had a prob, then again I haven't had to lift my 05 yet. Is this OK?
Old Sep 23, 2005 | 08:07 PM
faawrenchbndr's Avatar
I've heard it is not, I dented my '75 Corvette crossmember that way. I believe there is a diagram in your owners manual.
Old Sep 23, 2005 | 08:25 PM
ATCS2004's Avatar
Look it up in the Owners Manual. Don't use the crossmember.
Old Sep 23, 2005 | 08:27 PM
kingfish51's Avatar
Owners manual says use the frame behind the front wheel. About where the front edge of the door is (approx).
Old Sep 23, 2005 | 09:40 PM
asinatra's Avatar
I use my crossmember all the time; jack stands on the lifting points, there is no reason to do one side at a time if your working with both front wheels for instance.
Old Sep 23, 2005 | 09:51 PM
JerseyGeorge's Avatar
I would use the frame rails behind the wheels. They support the weight of the truck not the cross-member...JMO
