Headlight switch move-gauge install-Efan led's
Old Mar 9, 2006 | 02:18 PM
Beefullo's Avatar
What did you use to cut into the dash?
Old Mar 9, 2006 | 03:05 PM
05SilverFX4's Avatar
Very Clean install!
Old Mar 9, 2006 | 03:58 PM
nuclearthreat54's Avatar
Nice!
Old Mar 9, 2006 | 04:08 PM
BlueFlareside's Avatar
That looks very nice. Great job!
Old Mar 9, 2006 | 04:37 PM
Josiah's Avatar
Originally Posted by Tun2One
I'm getting my Roush installed on Monday and I had to find a place for the vac/boost gauge. So I decided to move my headlight switch down (I have a 4X4 so I could not use the 'coin holder'). I also decided to install my Efan led's (green of course) and a switch so I can manually turn on one of the fans if I want. Here it is:
I'm curious, how did you take that lower gray panel off. I want to run wires into the cab on that side and I can't find a place that is accessible from the engine on that side besides a small spot by the pedals (wires would show there).
Old Mar 9, 2006 | 05:04 PM
StuckInMuck's Avatar
really clean.
Out of curiousity is there any reason at all that you wouldn't just want you fans running all the time? I really can't see a purpose for having them on a selectable switch? Or did you do that just so you can have a sweet switch in the truck? lol
Old Mar 9, 2006 | 05:57 PM
cvc14's Avatar
Very nice..
Old Mar 9, 2006 | 06:16 PM
red_candle's Avatar
Speaking of the coil holder
Anyone pull it out? My 4x4 has it, and that'd be a great place to stick a gauge.
How do you get the holder out without breaking something?
Old Mar 9, 2006 | 06:32 PM
enormous's Avatar
Originally Posted by StuckInMuck
really clean.
I have e-fans to be installed soon. At that time I'm installing a on/off switch to be used during river crossings. To access my favorite deer hunting areas I need to cross reasonably deep rivers. Shutting them off at that time is a good idea, maybe not the only one but an important one to me.
Norm
Old Mar 9, 2006 | 07:18 PM
26point2's Avatar
That's a nice install...I'm planning to do the same thing this weekend, minus the boost gauge. I think I'm going with red LEDs tho...I think it will look better on the gray...my opinon of course..
Well done.
R/
Craig
Old Mar 9, 2006 | 07:29 PM
Josiah's Avatar
Well done.
R/
Craig
Not sure where you're going to run the wires, I am still on the fence about getting that gray panel the headlight switch is on, off. Let me know if you figure it out.
Old Mar 9, 2006 | 07:43 PM
26point2's Avatar
Actually I was looking at it today...the panel just below the stearing column comes off with two screws and two snap connectors...after I took that off I was able to reach my hand around to the back of the grey panel. My only problem is running the wire from there...ground, power and signal (green cable on the controllers)...and where to go thru the firewall...worst comes to worst I think it will look good on the panel below the column...I also have the spot on the dash just to the left of the radio...I believe on the Lariat there are some switches there, mine, FX4 has just some blanks.
To answer your first question: I don't know how that grey panel comes off...but I believe I can work around it without taking it off...this is why I bought the truck...sit out in the garage and figure these things out...I'll let you know how it goes..
R/
Craig
Old Mar 9, 2006 | 08:27 PM
Josiah's Avatar
R/
Craig
I figured I would have to take off the panel next to it, the grey plastic is grounded much stronger. I was namely curious as to which rubber grommett I'd use in the firewall to route the cables. Please let me know which you choose to go with.
Old Mar 9, 2006 | 08:39 PM
26point2's Avatar
Yea, I was just thinking about that...I'll probably just go thru the fender where the antenna cable comes thru...I may just make another hole there and put in a grommett...just run the wires across the under side of the dash...I'll be able to tap into a 12v power source for the switch on the passenger side as well..
R/
Craig
Old Mar 9, 2006 | 10:02 PM
cvc14's Avatar
I want to know how he mounted the headlight switch there? How does it attach to the dash. B/c I want to add a tranny temp guage and I was looking at the a piller pods but I am not a big fan of those.
