Rear blocks removed........with pics!
Old Sep 19, 2005 | 05:51 AM
SoundPer4mance's Avatar
my truck is lowered in the back, and i just hauled around a 71 maverick, 72 gran torino, and a 65 galaxie. with the trailer i was pulling 8000 lbs, and it did squat a little, but nothing crazy. for me its worth it to have the lowered rear, and its somewhat for looks, but mostly for handling and ride quality. for the amount of times i actually load down my truck, its worth the trade to have it squat a few times
Old Sep 20, 2005 | 09:24 PM
indyeng's Avatar
Matt 05'FX4:
Can the 4x4 u-bolts be cut, instead of using the 2wd bolts? Thanks.
Old Sep 20, 2005 | 09:39 PM
Matt 05'FX4's Avatar
That is only possible if you add a few inches of thread to them with a die (from a tap and die kit) because if you have a look at em, the threads only go up for a few inches and if you whack off that 2 inches, there will no threads left. But yes, this is very possible and almost what I did, but I wanted the option to change back if ever needed and wanted to keep my old stuff.
Old Sep 20, 2005 | 10:18 PM
indyeng's Avatar
Sounds good. Thank you for the reply. I think I'll do the same and buy new.
Old Sep 20, 2005 | 10:32 PM
SteveVFX4's Avatar
sent you an email...
Old Jan 21, 2010 | 03:26 PM
spann352's Avatar
If you take the blocks out of the back of the truck do you need 2wd u bolts or can you use the stock u bolts i know that they will hang down some but i dont need clearance i just wanted the look
Old Jan 21, 2010 | 03:30 PM
spann352's Avatar
nevermind the last reply could i just put the block on top of the spring as you can in a chevy?
Old Jan 21, 2010 | 03:41 PM
Windsor's Avatar
Looks good. Air bags would be the solution for loads. I'd rather have my truck level all the time than the occasional 1,000 lb. load.
Old Jan 21, 2010 | 03:55 PM
Tornadom's Avatar
Holy (4.5 year) Old Thread Batman!
Old Jan 21, 2010 | 04:12 PM
Ballin STX's Avatar
LOLOL, thats what i'm saying!!!
Micheal's Avatar
At least we know some people do use the search.
Old Jan 21, 2010 | 04:27 PM
spann352's Avatar
do i need to buy the standard load or heavy duty u bolts for the rear to fit? i have a 4x4 that i want to take the blocks out
Old Jan 21, 2010 | 05:03 PM
Windsor's Avatar
spann352, you need the standard load u-bolts.
Old Jan 22, 2010 | 01:44 AM
noregrets's Avatar
LOL old thread but yay for using the search feature.
