is this rotor deal any good?
Old Sep 15, 2005 | 12:14 PM
silver-gt-vert's Avatar
2 front and 2 rear, drilled and slotted rotors for $275?
http://cgi.ebay.com/ebaymotors/Ford-...pagenameZWDVW#
Old Sep 15, 2005 | 12:21 PM
Will the same set fit the 1997 and the 2004? I thought the 2004 had 6 lugs.
khendrix2374's Avatar
hard to believe those are real brembo products.
Brembo is usually expensive stuff.
Looks like a good deal to me.
Edit: Good call bluejay. 04+ has 6-lug bolt pattern
Old Sep 15, 2005 | 12:34 PM
kingfish51's Avatar
They probably should have labeled it 97-04 Heritage.
Old Sep 15, 2005 | 01:46 PM
RamSS/T's Avatar
For what its worth I bought a set of these for my 02 WS6 convertable and they were great rotors...I could not have been happier with them. But you guys are right...these are for the 04 Heritage, not our trucks.
Old Sep 15, 2005 | 02:03 PM
PiggNFord's Avatar
For only $275, you can drill the extra hole in there!!
Old Sep 15, 2005 | 02:24 PM
Screw2004's Avatar
OK just called the seller ad he has the kits for our trucks 150.00 front 150.00 rear i will be picking up a pair on monday since he's only about 1hr from my house
Old Sep 15, 2005 | 02:28 PM
CRF250Racer's Avatar
Screw2004, PLEASE give us a detailed write up as SOON as you have these installed !!! I really want these and that is a killer price but sounds too good to be true !!
THANKS ...
Old Sep 15, 2005 | 02:31 PM
Screw2004's Avatar
THANKS ...
No problem CRF250Racer
by the way did you get the info on the airbag's for our slamed Screw?
Old Sep 15, 2005 | 02:35 PM
Airbags for a dropped screw appears to be a BIG problem ... Still no answer from anyone and I'm trying to locate a shop in southern Cal that does custom work on lowered trucks to see if they might be willing to fabricate something. Looks like it is going to cost me more time and money than I origionally planned !!!
Old Sep 15, 2005 | 03:03 PM
Eventhough the ones posted on eBay are for a heritage, the deal still applies for the 2004+ models, not Heritage. I was quoted $147 for the 4X4 fronts (pair) and $147 rear (pair).
Damn good deal if you ask me. I wonder if these are regular Brembo's and the guy machined it himself?
Old Sep 15, 2005 | 03:11 PM
Screw2004's Avatar
Ok homeboy check out mcgaughy's suspension they have what you need
Old Sep 15, 2005 | 03:20 PM
RamSS/T's Avatar
The ones I got looked like they were not factory drilled and slotted but the machine work was well done and they had been zinc plated. Like I said I was VERY please with mine.
Old Sep 15, 2005 | 03:43 PM
asinatra's Avatar
(559) 226-8196
I think they are buy the airport here, might have to stop by and see what they can do for me as well.
Old Sep 15, 2005 | 04:10 PM
fryjr's Avatar
I don't think they are Brembo from the looks of them and even Brembo states the following on their website:
This is the basic line of the High Performance Brake Systems program. It is a braking system consisting of an integral disc, available drilled or slotted, and a complete set of high performance brake pads. The Sport Line products can also be sold as separate components.
They still look better than stock and perform just as well I am certain.
