Magnaflow price
Magnaflow price
Hey guys...planning on buying a magnaflow real soon and wanted to know if this is a good price? This is exactly what i want?http://www.proficientperformance.com...&Store_Code=PP
Check out www.hottexhaust.com with coupon code fordtruck8
I bought the Magnaflow 15827 for $409, the system you want with coupon and free shipping is $393.48
Good luck!
-Chris
Good luck!
-Chris
Yes, www.hottexhaust.com is the way to go as far as cost. I got a SISO (w/ coupon code) for around $365 shipped very fast and well packaged.
Also, be sure to check out our Supporting Vendors including Troyer Performance which sells the Maggie kits as well.
It may be to your advantage to see if they would match a price... just FYI!
RP
RP
Hey quick question for you guys...i have a build date of 03/04 which is an early model. This is the exhaust i want and it says it only fits late 04 and 05 models. I assume i wont work then? how much did they change within the first year? I actually wanted duals straight out the back...that first website was the side exit.
Originally Posted by Rochester
I would like to know, how long did this take you to install, what tools did you use? Did you run into any problems along the way?
EDIT: oh and when I got all the hangers off, I supported the rear of the exhaust with a 5 gallon bucket turned upside down while I whacked at the front so it wouldn't sag down so far.
http://www.proficientperformance.co...s&Store_Code=PP
actually you don't hammer the muffler section off, or you'll be hammering for awhile and break something.......
After you've loosed all of th scews and unscrewed all the hangers......You turn the whole exhaust counter clockwise to unlock it from the stock pipe in front of the muffler.. there is a bolt that is in a slot and you have to turn to line it up before you push the exhaust out....
I did this and then kicked the muffler off from the front...
