2" drop shackes
Old Sep 5, 2005 | 04:56 AM
fourpointsix's Avatar
2" drop shackes
Who makes the 2 inch drop shackles for a 2005 F150? Can I put these on myself or do I need a shop to do it? Thanks for your help!
Old Sep 5, 2005 | 06:01 AM
SoundPer4mance's Avatar
do a search, this has been covered 100 times. i use the Ground Force shackles, yes you can install them yourself
Old Sep 5, 2005 | 07:31 AM
GB150's Avatar
I used the Ground Force shackles also. Easy install.
Old Sep 5, 2005 | 10:44 AM
jpdadeo's Avatar
I used DJM but there are several brands available. Installation is simple and can be done in your driveway in less than an hour; all you’ll need is a couple of wrenches and a jack stand or equivalent. Wait until you have both sides done and the truck back on the ground before you do the final tightening of the four bolts; don’t over-tighten
Most of the kits come with instructions
Old Sep 5, 2005 | 10:46 AM
faawrenchbndr's Avatar
Why not just remove the 2" blocks that are in the truck from the factory?
Old Sep 5, 2005 | 10:54 AM
jpdadeo's Avatar
4x4 have blocks * 4x2 don't
Old Sep 5, 2005 | 10:57 AM
jpdadeo,
Thanks, I thought they both did.
Old Sep 5, 2005 | 12:56 PM
If you're interested, drop me an e-mail and I can send you a "photolog" that I compiled while installing my GroundForce shackles. A fairly easy install if you're at all mechanically inclined!
Old Sep 5, 2005 | 02:50 PM
rm328's Avatar
Can you send me those pics??
Old Sep 5, 2005 | 04:03 PM
Tical84's Avatar
I'd also like a copy if you don't mind.
Email addy is in the profile.
Thanks!
Old Sep 5, 2005 | 04:24 PM
I'd like to see those too! Thanks man.
Old Sep 5, 2005 | 11:51 PM
Sending them, guys!
Old Sep 6, 2005 | 01:18 AM
Tical84's Avatar
I got the email, excellent job. Probably one of the most detailed and easy to follow tuts I've seen. Should help out alot.
Thanks!
Old Sep 6, 2005 | 01:11 PM
rm328's Avatar
Thanks!
I agree! Thanks.
Old Sep 6, 2005 | 05:37 PM
Quintin's Avatar
I used 2" DJM shackles on my '04 Supercab:
DJM makes them, Ground Force does, Belltech, and I think H&R just recently released 1-1/2" rear shackles. Stylin' Concepts has the DJMs and Ground Force shackles in stock. Ain't really nothing to installing them, just be advised, on some trucks you may get a vibration during acceleration because the pinion angle changes. Ground Force includes pinion shims for this, DJM doesn't, and I don't think Belltech or H&R does. Won't know if this will apply to your truck until you try. I had a low speed vibration on acceleration from 30-40 mph, until I raised my shackles up to the 1-1/2" hole. The vibration ain't no where near as bad as it was at 2", but it's still noticable. I'll shim it someday, but for now I ain't gonna worry about it.
