Off set on Rims I Picked
Old Aug 29, 2005 | 06:09 PM
04Lariat05kr's Avatar
Unhappy Off set on Rims I Picked
Just spoke with the Mfg of Oasis, and asked for a price quote on Oasis Titan Wheels size 23" X 10 " and he said those rims have a small off set and might stick out a little being that a 2004 F150 has a very small off set. Please help is this true I don't know much about this? He was really nice thou and offered to ship me one to see if I like the look of it.
Oasis Titan
Old Aug 29, 2005 | 06:32 PM
dzervit's Avatar
Well what IS the offset of the wheel?! Stocker have backspacing of 5.5-6" or something like that... search the wheels forum, it's been covered again and again and again and again and again...
Old Aug 29, 2005 | 07:18 PM
freekyFX4's Avatar
Those wheels are like $900 each, right?
Old Aug 29, 2005 | 07:23 PM
ThumperMX113's Avatar
The only thing is they are also 10" wide so you gotta calculate the backspacing with the width of the rim also.
Old Aug 29, 2005 | 07:55 PM
wandell's Avatar
Yeah, what is the backspacing on them? The backspacing on the OEM 7.5 inch wheels is 5 1/2 inches.
Old Aug 29, 2005 | 10:15 PM
cards89's Avatar
you need atleast a 35mm offset.
Old Aug 30, 2005 | 12:47 AM
RamSS/T's Avatar
They will be fine. The front one will stick out about 3/8ths of a inch more than the back, but its not noticible. The front tire will be about even with the plastic fender flare (it wont stick out past it) and the back will be about even with the metal fender lip. If you dont have flares (I asume by your name ID you do though) they will stick out a bit more.
Here are pics of my 24X10s but they should be about the same:
Why would you go with a 23? The 24s are only a few hundred more and would look a lot better. These trucks swallow rims and the 23s wont look that big on it.
Old Aug 30, 2005 | 02:35 AM
charlesA's Avatar
+44 offset
im pretty sure that is the offset for 2004+ so even if you did have a +35 offset, you'll still be sticking out no matter what. RamSS/T is right, you'll be fine even if they stick out 3/8ths of an inch....as long as you dont drop the truck, then the rear metal fender lip will chop the tires up good .
It's also true that these trucks have a big wheel well and even my 24's doesnt seem to look big, 26's seem to match-up with the wheel well IMO
Old Aug 30, 2005 | 10:48 AM
I found a website that has them for $700 each.
http://www.customwheelsdirect.com/wh...re_size_id=319
And I will post the backspacing and off set of the wheels as soon as I get it.
Old Aug 31, 2005 | 09:22 AM
E-mail from the sales rep at Oasis:
Ricky I just checked the 23" titans and I do not have enough to do one set
but I do have them in 24" and I can make you a great deal.
the offset is 30mm which should look fine thanks
is this fine?
Old Aug 31, 2005 | 06:32 PM
Oasis sales man e-mailed me that he didn't have enough wheels to make the set on 23" but he could sale me the the 24" for the same price. That's cool and all but I'm scared of the price of 4 tires for 305/35-24.
Old Aug 31, 2005 | 08:53 PM
RamSS/T's Avatar
The tires would only cost a couple hundred more than the 23s...I don't think a couple hundred more is much when your already spending several thousand.
Old Sep 1, 2005 | 10:12 AM
I see what your saying. It's a great deal he already knocked off 1104 off the rims. How much did you get your Kumho's for?
