Quote for gears
Old Aug 25, 2005 | 11:46 PM
chrisrud15's Avatar
Quote for gears
So i am taking my truck tomorrow to get a quote on the gear change 3.55 to 4.10. Ford wont do the change cuz it doesnt come stock on my truck. Whats a good price for install? Im buying the parts from here http://www.fordracingparts.com/parts...tKeyField=8606
My other question is: Is this all the parts I will need? All the seals and little stuff I need for the change. Diff Fluid? Anything im forgetting? Thanks oh yeah and i have reg cab 5.4 with 9.75 rear end. I had this on another post but didnt get too much of a response there. Sorry if you had to read twice.
Old Aug 26, 2005 | 11:21 AM
bigtruck311's Avatar
i have seen everything from $200-600 per axle depending on shop and location and length of warenty
Old Aug 26, 2005 | 11:23 AM
misato's Avatar
randys ring and pinion said $1600 out the door. 4x4 to 4.56's
for a bronco a local guy did it for 300/axle (they were out of the vehicle)
Old Aug 26, 2005 | 01:06 PM
jdoggfx4's Avatar
I got a quote of 1500 for 4:56's front and rear with whatever warrenty the gear comes with.
Old Aug 26, 2005 | 04:22 PM
brypink2's Avatar
I was quoted $1600 for 4.88's front & rear and $1900 w/ a 3/36k warranty. But...I am getting it done cheaper because I'm buying bigger tires at the same time.
Old Aug 26, 2005 | 09:48 PM
SoundPer4mance's Avatar
im having a ford tech do it at the dealer for $100, paid $120 for the gears and $100 for the LS unit
Old Aug 26, 2005 | 10:02 PM
brypink2's Avatar
Originally Posted by SoundPer4mance
im having a ford tech do it at the dealer for $100, paid $120 for the gears and $100 for the LS unit :wink:
I want to see the receipt
Old Aug 26, 2005 | 10:07 PM
for which? i was going to have the labor done tomorrow, but i cant afford it now, if you like ill PM you a pic of the reciept...........
Old Aug 26, 2005 | 10:08 PM
chrisrud15's Avatar
Sound4performance,
Thats an awesome price. Did you go with the ford 4.10"s? Is he doing these at the ford dealership or at his house? warranty? I wish i could get ford to do it so i could get the warranty. I know a ford tech who i think is going to do it for me. No warranty though! He's only charging 125 bucks plus 184.00 for the gears
Old Aug 26, 2005 | 10:12 PM
ive got a used POSI (5k miles) and used Ford gears (7k miles), 4.10s. ideally i would have liked new gears, but i cant afford them. a ford tech agreed to do it for $100 cash but he needed a lift, so i talked to the service manager who always helps me out and hes writing a service ticket on it so the tech gets $100, so in reality i may pay like $110-120 labor (shop supplies etc etc). although none of my information really helps you out since im getting a pretty good deal that youd be hard pressed to find anywhere else. i havent asked but im assuming it wont be covered by warranty.
Old Aug 26, 2005 | 10:14 PM
chrisrud15's Avatar
So with the gear set that i can get at fordracing.com does this include everything i need? No extra stuff that i need for them to install?
Old Aug 26, 2005 | 10:22 PM
for $184 id bet youre just getting the ring and the pinion, you would need an install kit separately im sure, as well as gear oil LS additive. the kit should come with bearings seals shims, crush sleeve, etc.
Old Aug 26, 2005 | 10:23 PM
brypink2's Avatar
I'm just busting your *****...I wish I could get that kind of hook-up!
Old Aug 26, 2005 | 10:36 PM
chrisrud15's Avatar
Anybody bought these 4.10 gears from ford. Im gonna call tomorrow and find out what is included. How much should the kit cost me? I dont wanna spend more than 500 hundred on parts and install. I know thats low but the install is gonna run cheap. Thanks
Old Aug 27, 2005 | 07:31 AM
an install kit could run $75-100, gear oil and additive maybe $30, that leaves you around $220 for gears if you get the install for $125
