15K check up and tranny work
Originally Posted by suncoast ford
"Change engine oil and replace oil filter (Up to 5 qts of motor oil)"
better check your oil, a 5.4 needs SEVEN quarts!
Originally Posted by freekyFX4
I still don't understand why you guys have so much trouble with your trucks. I guess if you look hard enough, you can find a problem with anything.
Do you know what exactly did they did to fix your truck Acticus? I'm very happy to see that they got it all worked out but I'd like to know what they did to fix these issues, as the clunking drivetrain is pretty common on these trucks (like mine). I figure it is just play in the driveshaft/slip-yoke, and they probably lubed yours.
