Rattle in the headliner?
Old Aug 19, 2005 | 02:09 PM
5150steves's Avatar
Anyone else have a rattle in their headliner? Any ideas how they can fix it?
Other than that and the gas milage I have been thrilled with the truck.
Old Aug 19, 2005 | 02:16 PM
asinatra's Avatar
TSB
05-14-2
Headliner Buffeting/rattle Noise - Vehicles Equipped With Roof-opening Panel And Built Prior To 6/1/2005
Old Aug 19, 2005 | 02:22 PM
5150steves's Avatar
Thanks but what is TSB?
Mine was built in May 2005 and has a moonroof.
Old Aug 19, 2005 | 02:27 PM
kidtriton's Avatar
that tsb basically says to add to the existing 2 blocks of foam that are on each side of the dome lamp to get the blocks not to have a gap between them and the roof. You get up in there by taking off the moonroof opening trim, and sliding your hand up in there. I had a 04 with a moonroof that rattled, and i fixed it myself by carefully putting some epoxy on top of the existing foam blocks and then holding them up against the roof until dry.
Old Aug 19, 2005 | 02:40 PM
5150steves's Avatar
Great. Thanks.
Old Aug 19, 2005 | 03:09 PM
Buck Henry's Avatar
Originally Posted by kidtriton
You get up in there by taking off the moonroof opening trim, and sliding your hand up in there. .
Not sure if this is any easier, but I was able to get to the foam blocks via the rear dome light opening.
Old Aug 19, 2005 | 03:10 PM
RobNY's Avatar
Check this thread...Do a search in the interior care section
https://www.f150online.com/forums/sh...ight=headliner
