Sway Bars and Shocks
Old Aug 10, 2005 | 12:45 AM
flanaganman's Avatar
do u have part #s what was the cost ? where did u buy? thanks. i would like to trade out my shocks hate that bounce in the rear when i go over a bump.
Old Aug 10, 2005 | 06:28 AM
ThumperMX113's Avatar
How big of a steering nibble problem did you have?
Im debating of just investing in a set of good shocks to try to get rid of my nibble.
Old Aug 10, 2005 | 04:41 PM
mwheue's Avatar
Bought shocks at www.eshocks.com
Old Aug 10, 2005 | 04:44 PM
mwheue's Avatar
I had a relatively small steering nibble problem. But now I don't have a hint of any problems. I wont say I have a much softer ride now, But I would say a more controlled ride.
Old Aug 11, 2005 | 09:17 AM
GB150's Avatar
When people on this board first started putting on the Bilsteins, some were reporting that the shocks actually lifted the truck about a 1/2 inch. Have any of you that have made the switch to Bilsteins noticed a slight lift? i have a 2wd and dont want a lift.
Old Aug 11, 2005 | 10:03 PM
mwheue's Avatar
Didnt notice any ride height difference. Just a more controlled ride.
Old Aug 11, 2005 | 10:29 PM
kwr's Avatar
kwr
I have 2" drop shackles. Will the HD Bilsteins work or will they be to close to bottoming out? Does anyone know of a drop 'shock mount' kit for our trucks?
Old Aug 11, 2005 | 10:53 PM
mwheue's Avatar
KWR, You might ask someone like jpdadeo if when he had his drop shackles on if he used the stock shock. If so I think the bilseins would work.. Just a thought..
Old Aug 11, 2005 | 10:56 PM
kwr's Avatar
kwr
Thanks Mwheue!
Old Aug 11, 2005 | 11:23 PM
kd4crs's Avatar
I have the Ground Force 2" drop shackles on and kept the stock rear shocks. The shocks actually seem to work better with the drop. Probably due to the increased weight transfer from the drop.
Old Aug 11, 2005 | 11:26 PM
GB150's Avatar
Ditto.
Old Aug 12, 2005 | 12:43 AM
Toreadox's Avatar
Originally Posted by mwheue
Front sway bar took about a hour, but if I did the same job again it would take about half that time. Most of the time spent figuring out the correct bar end positions. Rear sway bar took 1/2 hour and was very easy to install. Keep in mind I have a compressor and air tools so job goes much faster. Shocks.. I only did the rear shocks and they took 1/2 hour also. Front shocks I had done at a garage due to the lack of a flat surface to work on. I will post pics in a short while here.
Hey MHeue, Did you need the compressor and air tools mostly for the shocks? I've already had Bilsteins (love them shocks) installed but have been wanting to add the Hellwigs front and back. Can I do the Sway bar with only torque wrench or do I need the air tools? Thanks.
Old Aug 12, 2005 | 05:18 PM
mwheue's Avatar
You do not need air tools to do sway bars or shocks. I used them because they make the job go alot faster. Added that as a time reference only as I was being asked about install time.
Old Aug 13, 2005 | 06:13 AM
fujio001's Avatar
Just a quick question, if I already added a rear Hellwig, should I change the front as well? Thoughts, comments? Maybe I should just replace the bar bushings to polyurethane.????????
As for Bilsteins and a 2" drop, I dropped the rear of my truck and am still using the Bilsteins. They still work pretty darn good! I have no problems bottoming them out.
Old Aug 13, 2005 | 06:25 AM
poptop's Avatar
ill ask that too i was thinking about adding a rear sway bar but it never dawned on me to change the front is there that much diff between the stock bar and the hellwig??????
