Lift question
Lift question
Ive seen posts where a people have put a 2 or 2.5 in lift kit ( autospring, daystar or whatever) in their 2wd OR 4WD and it makes either of them level. How can the same spacer make a 2wd or a 4wd level? Am i missing something? I dont think i have heard of many 2wd owners having to add blocks......
I believe the 4x2's sit about 2 inches lower in the front and rear compared to a 4x4. If you add a 2.5 inch leveling kit to the front of a 4x2 and a block in the rear it will put you at just about the same height as a stock 4x4. However, your rear end will still be two inches or so taller than the front, and most people want their truck to sit level. That probably why most 4x2 and 4x4 owners don't install a block or add-a-leaf with their leveling kits.
Originally Posted by ThumperMX113
Thats correct.
IMO if you were going to lift a 2WD. Do it right. Buy a 2.5" Leveling Kit with the factory 4WD rear blocks.
