Airforce One noise level?
If you didn't want the intake noise, why did you buy a cold air intake? I have yet to hear a quiet cold air intake. By design the filter is "mostly" exposed and thus the noise. From the three that I have heard on the newer 5.4 3v F150's, AF1, AirRaid and Volant, I think the AF1 is the quietest. Although I have to admit the AirRaid is probably pretty close. I don't hear anything until about 2K rpm and my friends AirRaid starts at about 1.8K rpm. Once they are both wide open I can't tell the differance.
As far as throwing CELS on the very early F150's I have had one CEL at over 500 miles and one at just over 200 miles, all are supposed to be taken care of with the new tube design. (I am awaiting shipment) Troyer Performance has taken care of it with no pain on my part.
Originally Posted by jrack04
Now I understand why people say that their Airforce One is louder than that Magnaflow SISO.
You'll never hear me say that and I have both... in fact, I can BARELY hear mine...
Like has been mentioned, my filter is substantially closer to the heatshield. Not sure if that'd make any difference at all...
The only time I hear mine is when I have my driver's window down and bring it up around 2K RPM moving or sitting. Short of that, I can't hear it.
RP
RP
RP
Your not kidding when you say "substantially" closer to the heatshield. I may have to give it a test tomorrow.
RP:
Side note. Are you close at all to Ashland, Kentucky?
I case anyone needed a 2nd opinion on whether flaring out the end works. It does. Turns out the gentlemen who came up with the idea decided to move to a slightly bigger rig and sold his customized AF1 to me. Search for post by tycreek. You don't notice any real difference from the stock intake noise until you get up to around 2300 rpm. But even then it's not too loud or annoying. So I was relieve it didn't sound too loud but I'm still on the fence as to whether it produces enough of a gain in hp to justify the cost. Only had it a couple of days so we'll see.
i just installed mine about a week ago...No codes.. thank god!. . .the only thing was the mass air sensor didnt fit, i had to mod that... as far as sound.. idle, very quite, WOT.. very loud.. it sounds like an old 92 lx coupe, just that throuty (sp*) sounds, but from under the hood...its very loud in the cab at WOT, but like i said, idle, and jsut driving its pretty quite.. .i have the filter as far on the end as i can get it before it falls off..
chris
chris
Like some on this thread, I had to dremel out the MAF sensor socket in order to insert the sensor. Otherwise, installation has been trouble-free.
I have the revised tube design on my truck and can tell you it can barely be heard. Truly quet.
I've had the CEL illuminated now for two hundred miles. The new tube design is supposed to help this, but I still have the same CEL that started with the original tube. I'm seriously thinking of deeply resetting the computer to see if the new tube can avoid the CEL while accumulating it's own operating ranges in the computer.
Do you have any pictures so that I can see your filter placement?
I did do a cold reset of the PCM this evening. The truck was cold and I turned the headlights on to drain the computer. No CEL yet, only 16 miles so far. Noise at full throttle is minor, but I'm not noticing much of a pick-up either... this could be due to the fact that I haven't performed any other mods (exhaust and programmer are next).
Thanks guys.
Just reading all these posts reminds me of driving my dads Olds many years ago with a 350 4 bbl. We would flip the air cleaner cover upside down to give it some noise when you stuck your foot into it. It's the same thing with todays systems, you open up the box, you are going to hear the noise of the engine swallowing air.
