Cylinder deactivation
Dodge is coming out with cylinder deactivation (basically running the truck on 4 cylinders to save fuel when extra power is not needed). I would love to see Ford come out with a retrofit on our trucks that allowed us to have cylinder deactivation. Anyone heard any plans? Ford are you listening?
Originally Posted by asinatra
They have it on their other cars currently, i paid for 8 cyl so i would expect them to run all the time. But it only comes on after so many miles of continous driving. Ford is ahead of the pack with their "gearless" tranny, just think that its a big rubberband and the two pulleys on each side get bigger and smaller depending on speed and acceleration.
I think it's a pretty cool system and would like to see Ford start dropping it on their V8s. I'd love to have the V8 power when I need it and for towing but be able to drop down to a 4 cylinder for when I have to cruise on the interstate.
Wait, Ford already has this but you have to let your truck overheat first
im with asinatra on this one, with the CVT transmission as well. several cars have been using them for a while, only recently has ford started putting them into production. the 500 is the only car that comes to mind.
The 500's sister, the Montego has the CVT available as an option on front drivers and it's standard on AWD models. The Freestyle is the same, and the Escape Hybrid is available only with the CVT. The CVT itself is a cool transmission, a lot of other manufacturers canned their CVT projects because of durability problems. The belts would stretch and slip. Ford went above that by using chains instead of belts.
I was worried about this since I thought I was mashing gears everytime I placed it in reverse.
how is a f-150 gonna cruse on four cylinders...and than have four kick in when needed..I'm used to the trottle lag on my truck, to wait for 4 cylinders to kick in + throtle lag would not be practical for towing/hauling.
Dodge is a head of the game is some area's with the new Charger/Challenger/Mandum/300 C all ford has is the puffed out Taruis ( Ford 500 )
cylinder deactivation can work on cars....I don't think is practical for trucks.
Originally Posted by HIDPLANET
Thats interesting info. I havent done alot of studying since I bought my truck. So this may be the reason why when its put in reverse, it doesnt actually kick in until you start rolling forward a few inches right?
As far as the freewheeling in the F150's, it scared me when I first pulled out of the dealership (up an incline) on the test drive. The truck rolled backward when I went from brake to gas...never had an auto do that before. Test drove two more F150's, all did it...I'm used to it now, but it's weird for anyone not used to it.
It can be programmed into the computer that under light accel and cruising it will run on alternating 4 cylinders. Under moderate to heavy accel all cylinders will fire and when O/D is off, it will also keep it from going into 4 cylinder mode.
It's a litlte computer program that even if it only added 1mpg I'd take it. The trucks already have the basis of the programs built in for when the engine overheats.
Originally Posted by Curmugeon
With 4 cylinders deactivated, Dodge claims only one (1) MPG gain on the highway, slightly better in the city...big deal!
