A/C compressor always engaged?
Old Nov 19, 2006 | 12:57 AM
expy03's Avatar
No that is a gas mileage and reliability thing
Must agree. I lose 1 mpg with compressor on. And with a cold engine, having the Compressor on is just adding to the wear and tear during warm up. I always turn everything off before engine shut down.
Quintin's Avatar
Originally Posted by gotshot
well I have the thump too. It started every once in awhile but now it even does it at idle. It seems to do it in the mix heat and defrost or defrost position when the compressor kicks in. It started after a cam phaser replacement so I dont know if they messed something up but it is going to the dealer on monday. Ill let you know what I find out.
If they replaced the passenger's side phaser, they probably undercharged the A/C and/or got some air in with the refrigerant when the system was charged.
Old Nov 19, 2006 | 03:18 PM
gotshot's Avatar
I thought they probably did something. It definantly only does it with the selector switch in mix or defrost only. I praised them for the extra effort they did with finding a bad injector, I guess we all cant bat 1000.
