Parking Lights are staying on..........HELP
Old Jun 14, 2005 | 06:22 PM
DarkShadow04's Avatar
i just noticed today that my parking lights are staying on after i exit and lock the truck. the light switch is off inside as it the dome light. is this a signal for a low battery in the key fob or what does it mean? someone please help
Old Jun 14, 2005 | 06:27 PM
kd4crs's Avatar
Parking lights staying on is a malfunction of the remote keyless entry system. The only low battery indicator the keyfob has is reduced operating range or failure to operate entirely. There was another post recently about someone's horn continuing to blow after double clicking the lock button on their keyfob. Gremlins!
Old Jun 14, 2005 | 06:45 PM
so one would think after replacing the battery (which i did) then it would fix itself. so now how do you fix it?
Old Jun 14, 2005 | 06:51 PM
kd4crs's Avatar
It sounds like a stuck relay for the lights in the remote keyless entry system. I'm not sure where the module for it is located but it will probably need to be replaced. Maybe if the relay is seperate from the module it can be replaced by itself. Either way it sounds like a trip to the stealership to me.
Old Jun 14, 2005 | 08:30 PM
so now i know its the remote system, the truck wont disarm or rearm now. so how do you reset the system, i have tried to go into program mode but that wont work either. so now i just disconnected the battery in hopes that it might work. any other ideas?
