Question for Retrax owners
Old Jun 12, 2005 | 05:46 PM
Recurve's Avatar
That little brass pipe that the drain tube connects to got pushed up into the housing. I can't hear it or retrieve it. Should I order another-can it be pushed in from the bottom? Is this a big deal or can I superglue the tube to the washer or something and then to the cabinet? Looking for any thoughts or suggestions. It is still under warranty I believe but an hours drive, taking off work etc.
Thanks so much!
Steve
Old Jun 12, 2005 | 10:06 PM
Recurve's Avatar
ttt
Old Jun 13, 2005 | 11:15 AM
resopkr's Avatar
Recurve,
You'll need to remove the anchors from all four corners. Then fully extend the cover and lock it into postition. Get somebody to help you move the cover back enough to make room so that you can get in the front of the bed. With the cover fully extended you should be able to see and get your hand down into the housing to find and replace the brass fitting.
Hope this Helps!
Old Jun 13, 2005 | 11:50 PM
Recurve's Avatar
Thanks!
