Troyer tune & deserted road =
https://www.f150online.com/galleries....cfm?gnum=6008
Was out playing after installing the AF1, and the new tunes from the X-Calibrator tuner, and the new Goodrich 285/70/17's yesterday.
Not bad for a 6,000# 4x4 Supercrew from a dead start with "NO" powerbraking.
Truck smoked them all the way through 1st gear (150ft.) until I let up on it, then when it shifted it lit them up again.....Gotta love those Troyer tunes....
Here Hemi, Hemi, Hemi....
I Call BS
Strange....... my truck is lighter than yours (4x2) and i am also running Troyers XCAL tuned to 91 octane perf. You actually mean to tell me you think people will believe you saying you didn't powerbrake to do that???
I know my truck i quicker now, a race vs. my brothers Tundra showed me what the tune did, but im not going to get peoples hopes up saying you can do a "burnout" in these big *** trucks, i call B.S.
Also, the road look awfully moist and covered with sand....a VW Bug can light 'em up in those conditions.
ill just stick with the smoke show and some funny *** wanna be 360's in my truck, ill post a vid later on if all goes as planned...
this is why you don't power-brake
Originally posted by Superchips_Distributor (snip)
You're absolutely right, "stalling up" or "brake torquing" like that against the brakes will only slow you down in these (any most other non-race cars) vehicles. What happens is the tranny heats up (yes, just in that very short time) so it doesn't pull quite as hard in 2nd & 3rd from the PCM adding fuel & pulling timing in response to that load before you ever even leave the line, so it slows down a bit - for me, it's anywhere from 1-3 tenths, depending on how hard I stall it. Then of course the converter doesn't flash as high, so you don't leave *quite* as hard, and the combined effect is typically about a tenth, just like you found.
For your vehicle and most other street-driven automatics, even with slicks you get the hardest launch by letting the converter "flash" - sit there and idle & then just nail the throttle. It'll leave harder & give you a quicker ET. For the most part, only race cars with transmission brakes should stall it up.
