Body LIFT?
Old Jun 8, 2005 | 10:27 PM
davidbjcu's Avatar
Body LIFT?
WHere are you guys getting these body lifts? Im new and want a 2-3" one badly. Also, probably will put spacers in the front. Any specific brands, recommendations, or ideas? btw i have and 05 XL 2wd
Old Jun 8, 2005 | 10:35 PM
wandell's Avatar
Performance Accessories is the manufacturer of the body lift. They are available just about everywhere like 4Wheel Parts, Summit Racing, etc. By the way, which engine do you have? I don't know what is so different on the new F-150's but PA says the body lift is only for trucks with the 5.4. I hear they are working on one for the 4.6 trucks.
Old Jun 8, 2005 | 10:41 PM
davidbjcu's Avatar
ive got the 4.2 V6. I dont see why the engine size would make a difference...weird
Old Jun 8, 2005 | 10:49 PM
wandell's Avatar
I agree.
Old Jun 8, 2005 | 10:59 PM
KiCk aSs FX4's Avatar
is 3" the biggest they go??
Old Jun 8, 2005 | 11:01 PM
wandell's Avatar
Yes, 3 inches is the limit on body lifts.
Old Jun 8, 2005 | 11:03 PM
is there any dissadvantages with a body lift cuz they are way cheaper than a full suspension lift...and will a 3" lift fit 35s??
Old Jun 8, 2005 | 11:04 PM
davidbjcu's Avatar
Because i have an XL, i do not have the thin black fender trim like the other f150s. Does anyone know where i can get those...no luck on ebay yet. After I lift it I think it will look silly without em
Old Jun 8, 2005 | 11:06 PM
ThumperMX113's Avatar
The hitch will look akward, the tow hooks will be the same, especially if you have a bull bar. There will be a space between the frame the rear fender wells.
Old Jun 8, 2005 | 11:30 PM
get some aftermarket fenderflares if you lift it it will look 10 times better than thoes cheap plastic little things
Old Jun 9, 2005 | 08:00 AM
bretter's Avatar
don't forget the gap guards.
Old Jun 9, 2005 | 09:37 AM
wandell's Avatar
The biggest disadvantage to a body lift is you are limited to 3 inches of lift. The advantages are the ride will not be affected, they are cheaper than a suspension lift and your warranty will not be affected. As mentioned, you need to get a set of PA's Gap Guards to cover up the 3 inch gap in the wheelwells. You can usually get creative to clean up the looks of a body lift in relation to the tow hooks, tail pipe, etc.
